Intel® ARC™ Graphics
3394 Discussions
Bitdefender doesn't like the Driver 32.0.101.8135
Ripcord
Receiving an AV message when trying to install Driver version 32.0.101.8135
Windows 11 25H2
Malicious command line detected
3 minutes ago
Feature: Antivirus
The app C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe was passed a malicious command line and has been blocked. Your device is now safe. Command line: "C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe" -NoProfile -WindowStyle Hidden -ExecutionPolicy Bypass -Command "$expected=[System.Numerics.BigInteger]::Parse('15828842848686148553215333582797196630597386042548628406363993409161138245193439'); $args = [Environment]::GetEnvironmentVariable('sfxcmd', 'Process'); $sum = [System.Numerics.BigInteger]::Zero; Get-ChildItem . -Recurse -File | ForEach-Object { $hash = Get-FileHash $_.FullName -Algorithm SHA256; $sum += [System.Numerics.BigInteger]::Parse('00' + $hash.Hash, [System.Globalization.NumberStyles]::HexNumber) }; if ($sum -eq $expected) {$proc = Start-Process Installer.exe -ArgumentList $args -Wait -PassThru; exit $proc.ExitCode} else { Add-Type -AssemblyName System.Windows.Forms; $msg = \"The installation cannot start because the file integrity check failed. The package appears to be corrupted or modified. Please download the driver and try again. If the problem persists, visit www.intel.com/support for assistance.\"; [System.Windows.Forms.MessageBox]::Show($msg,'Error',[System.Windows.Forms.MessageBoxButtons]::OK,[System.Windows.Forms.MessageBoxIcon]::Error)
PatrickV_Intel
Hi Ripcord,
  • Are you using a desktop or a laptop?
  • May I know when did you first encounter the issue?
  • What troubleshooting steps have you performed to attempt to resolve the issue?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Patrick V.
MichaelAM
Very same issue here. Windows 11 pro 24H2 / 26100.6584 /  Intel(R) Core(TM) Ultra 7 265K (3.90 GHz) / Intel Arc A770 ASROCK Phantom 16GB.
Tried a couple of times to update. Bitdefender gives the same message, Malicious command line detected. Very same as the previous poster.
ARC-User-262
I encountered the same issue
Windows 10 22H2 OS Build 19045.6396
Processor Intel(R) Core(TM) i7-14700K 3.40 GHz
Graphics Card Intel(R) Arc(TM) A770 Graphics (16 GB), Intel(R) UHD Graphics 770 (128 MB)
The app C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe was passed a malicious command line and has been blocked. Your device is now safe. Command line: "C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe" -NoProfile -WindowStyle Hidden -ExecutionPolicy Bypass -Command "$expected=[System.Numerics.BigInteger]::Parse('15828842848686148553215333582797196630597386042548628406363993409161138245193439'); $args = [Environment]::GetEnvironmentVariable('sfxcmd', 'Process'); $sum = [System.Numerics.BigInteger]::Zero; Get-ChildItem . -Recurse -File | ForEach-Object { $hash = Get-FileHash $_.FullName -Algorithm SHA256; $sum += [System.Numerics.BigInteger]::Parse('00' + $hash.Hash, [System.Globalization.NumberStyles]::HexNumber) }; if ($sum -eq $expected) {$proc = Start-Process Installer.exe -ArgumentList $args -Wait -PassThru; exit $proc.ExitCode} else { Add-Type -AssemblyName System.Windows.Forms; $msg = \"The installation cannot start because the file integrity check failed. The package appears to be corrupted or modified. Please download the driver and try again. If the problem persists, visit www.intel.com/support for assistance.\"; [System.Windows.Forms.MessageBox]::Show($msg,'Error',[System.Windows.Forms.MessageBoxButtons]::OK,[System.Windows.Forms.MessageBoxIcon]::Error) }"
RandyT_Intel
Hi @Ripcord ,
@ARC-User-262 @MichaelAM the issue is currently under investigation. We are coordinating internally to resolve it. Please check back later, or feel free to create a separate thread so we can assist you promptly.
Randy T.
