Hi Ripcord,
- Are you using a desktop or a laptop?
- May I know when did you first encounter the issue?
- What troubleshooting steps have you performed to attempt to resolve the issue?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Patrick V.
Very same issue here. Windows 11 pro 24H2 / 26100.6584 / Intel(R) Core(TM) Ultra 7 265K (3.90 GHz) / Intel Arc A770 ASROCK Phantom 16GB.
Tried a couple of times to update. Bitdefender gives the same message, Malicious command line detected. Very same as the previous poster.
I encountered the same issue
Windows 10 22H2 OS Build 19045.6396
Processor Intel(R) Core(TM) i7-14700K 3.40 GHz
Graphics Card Intel(R) Arc(TM) A770 Graphics (16 GB), Intel(R) UHD Graphics 770 (128 MB)
Hi @Ripcord ,
@ARC-User-262 @MichaelAM the issue is currently under investigation. We are coordinating internally to resolve it. Please check back later, or feel free to create a separate thread so we can assist you promptly.
Randy T.
