Intel® ARC™ Graphics
3469 Discussions
Diablo 4 crashing after a couple of minutes of play
Richieroo
Diablo 4 crashing within 5 minutes of play (usually within 1-2mins) since installing Intel ARC A770 16G.
In game I will be walking or in combat and game will freeze, screen will freeze and slightly tear and buzzing sound from the speakers. Have to reboot PC to resolve.
Happens nearly every first time I load Diablo 4 each day.
If my PC does not crash within the first 5 minutes, it wont crash later (have played some long sessions in Diablo 4 recently with no crashes), will always crash within 1-5 minutes of starting the game.
Was not behaving this way with previous Nvidia RTX 2080 GPU
Motherboard: Z590I AORUS ULTRA
CPU: Intel Core i9-10900F CPU @ 2.80GHz
GPU: Intel Arc A770 16G Limited Edition
Driver Version: 31.0.101.4514
RAM: 32637 Mb
OS: Windows 11
PSU: 850W
Jean_Intel
Hello Richieroo,
We want to inform you that we are investigating a crashing problem when playing Diablo IV. The driver developer team is working to implement a fix in an upcoming driver. However, we are unable to commit to an estimated time or updates regarding this matter but rest assured that it is coming soon.
We will further research this matter internally, bringing your information. We will post back as soon as we have further details.
Best regards
Jean O.
Jean_Intel
Hello Richieroo,
We want to let you know that we have been trying to reproduce the issue and could not observe any crashes yet with our latest drivers. Please note that a Timeout detection and recovery (TDR) crash can also occur due to an Operating System issue, we would like to recommend you use the System File Checker tool to repair missing or corrupted system files.
However, if these don't help and the issue remains, you may need to perform a clean Operating System Installation.
Best regards
Jean O.
Richieroo
 Was able to create the issue and have video and photo with arc in-game overlay showing
Richieroo
Here is video
issue occurred within 1minute of launching the game
Jean_Intel
Hello Richieroo,
Thanks for the information provided.
We appreciate the information you have shared with us. However, as we mentioned previously, the issue can be related to the Operating System having corrupted files. We would like to confirm if you have been able to try our recommendation for the previous post:
Best regards
Jean O.
Richieroo
Hi Jeano,
I have completed the System File Checker step (no corrections/changes occurred).
I haven’t completed a clean Windows 11 Install.
Keep in mind, this issue didn’t occur playing the same game using the same PC hardware and OS Installation. Only the GPU has changed.
I guess the true ‘fix’ is to go back to the Nvidia RTX 2080
Jean_Intel
Hello Richieroo,
Thanks for the information. Thank you for completing the System File Checker recommendation. We also understand that you haven't tried the recommendation for a Clean Operating System installation.
We will further review this matter internally with all the new information we gathered. We will post back once we have more details.
Best regards
Jean O.
Richieroo
FYI:
Arc Control downloaded and installed Driver version 31.0.101.4575 this morning.
Let's see how this goes
Richieroo
crashed again this morning
same deal. within the first minute of hitting the world. Gamer freezes, screen tears, and a thin black line is seen across the screen.
Forced to power down my system
Richieroo
I think it’s worse
getting multiple crashes per day now
have to give up on this game or GPU. Too frustrating
Jean_Intel
Hello Richieroo,
We would like to let you know that we are researching this problem internally. Once we have further details, we will be posting back. We appreciate your patience.
Best regards
Jean O.
Richieroo
another piece of info worth mentioning: I use an Acer Predator X34 monitor using the DP connector
Richieroo
also this issue reported on Reddit matches my same symptoms. Freezing screen and thin black line across
This user is using the same GPU and also an extra wide Acer monitor:
https://www.reddit.com/r/IntelArc/comments/11ovrym/having_a_weird_freezing_issue_with_my_arc_a770/
Jean_Intel
Hello Richieroo,
We are still researching this matter; however, we appreciate all the new information you are sharing with us. The more information we have, the better.
Best regards
Jean O.
Makavien
I would also like to confirm i get the exact same problem in game .Iy either just goes to desktop when
entering a dungeon or when i open portal iy crashes .Ive tryed a full ddu a full windows repair etc and
Still same problem.Ive switched back to my 6650xt for now to this is sorted
Jean_Intel
Hello Everyone,
Would you mind sharing a screenshot of the graphics settings for the game you're using? This would be very helpful for issue reproductions purposes.
Best regards
Jean O.
Richieroo
Jean_Intel
Hello Richieroo,
Thanks for all the information you shared. We will continue our research on this matter internally. We will post back as soon as we have more information.
Best regards
Jean O.
Richieroo
FYI: I don't think this is Diablo specific
I have had the freezing/PC crash during play on other games (Aliens Dark Descent, Hearthstone)
always seems to happen soon after I switch my PC on and load a game straight away.
It could just be coincidence, but it seems that freezing/crashing only occurs early in my gaming session.
If no crash within the first few minutes, it wont crash later
Jean_Intel
Hello Richieroo,
We want to thank you for your response regarding this problem.
We would like to inform you that there is a new driver update, and it includes multiple fixes for several issues. Please, test driver version 31.0.101.4644.
If the issue remains, please, help us to collect crash dump files to analyze them:
  • When the game crashes, a new dump file should be created under any of the following folders:
    • User-mode Application Crash dump: C:\AppCrashDumps
    • Small memory dump file: %SystemRoot%\Minidump (default)
    • LiveKernelReports: %SystemRoot%\Windows\LiveKernelReports
    • Complete/active memory dump file: %SystemRoot%\MEMORY.DMP (default)
    • App-specific dumps: Location is set by the application
  • Upload the dump file to your preferred file-sharing system (OneDrive, Google Drive, etc.).
  • Check our advanced troubleshooting guide for more information about how to enable debugging logs.
Jean O.
