Intel® ARC™ Graphics
3295 Discussões
Fc 25 Black Screen at Half time. Intel arc B580
awladhossen28
Principiante
2.266 Visualizações
Recently Bought an Intel arc B580. Previously owned a r9 380. I could play fc 25 on that no issues.. I bought The Gpu reinstalled fresh windows. But When I try to play A match in fc 25. My screen goes black at half time and doesn't load the 2nd half. And I have to Totally close the game.. It happens every time.
I attached a intel SSU report below. Also a vid of the black screen of FC 25 is attached below.. In this case the game managed to load into 2nd half but when I pressed classic then it again crashed.
Etiquetas (3)
18 Respostas
AlHill
Superusuário
2.264 Visualizações
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[IDSA needs to be abandoned, uninstalled and forgotten]
awladhossen28
Principiante
2.254 Visualizações
I attached a file as u said
stevejames
Principiante
1.601 Visualizações
@AlHill wrote:
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (:https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
Can you share the video procedure. Please attach the video url if possibly available on youtube. Although my windows is 64 bit, it keeps on crashing on my windows. Is it a bug?
awladhossen28
Principiante
1.592 Visualizações
It's 2.55 AM here right now. Can you specify what are you exactly struggling with? Is it fc 25 or support utility? I can record a vid and attach it here when i wake up tomorrow!
Earl_Intel
Moderador
1.953 Visualizações
Hello ,
I appreciate you for reaching out and providing both the Intel SSU report and video footage—those are incredibly helpful in understanding the issue.
I'm sorry to hear you're experiencing black screen crashes during FC 25 gameplay, especially after halftime. Let's work together to get this resolved.
To better investigate the root cause, could you kindly provide the following additional details:
System & Game Configuration
  • Are you running FC 25 through EA App, Steam, or another platform?
  • What are your in-game graphics settings (e.g., resolution, V-Sync, DirectX version)?
Driver & Software Behavior
  • Did you use DDU (Display Driver Uninstaller) before installing the latest driver?
  • Have you tried disabling ReSize BAR in BIOS to see if stability improves? Some users have reported reduced crashes when doing so.
Troubleshooting Attempts
  • Have you tested other games to see if similar crashes occur?
  • Are there any overlays or background apps running (e.g., Discord, OBS, MSI Afterburner)?
Optional Diagnostic Steps
  • Try launching FC 25 with lower graphics settings (especially shadows, textures, and post-processing) and DirectX 12, as this has shown better stability on Arc GPUs.
  • If possible, test the GPU in another system to rule out hardware-specific issues.
Once we have this information, we’ll escalate the case to our graphics optimization team for deeper analysis. Your feedback is vital in helping us improve the Arc experience, and we appreciate your patience.
Earl E.
awladhossen28
Principiante
1.857 Visualizações
Sorry I thought my replies were not posting cause of net issue.. thats why these extra replies are posted. I edited them.. IGNORE please Thank u!
awladhossen28
Principiante
1.851 Visualizações
awladhossen28
Principiante
1.851 Visualizações
awladhossen28
Principiante
1.906 Visualizações
System & Game Configuration :
Are you running FC 25 through EA App, Steam, or another platform?- EA App
What are your in-game graphics settings (e.g., resolution, V-Sync, DirectX version)?-
AUDIO_MIX_MODE = 0
CONFIG_APP_LOCALE = en-US
FULLSCREEN = 1
MSAA_LEVEL = 0
RENDERINGQUALITY = 4
RESOLUTIONWIDTH = 1920
RESOLUTIONHEIGHT = 1080
WINDOWED_WIDTH = 1280
WINDOWED_HEIGHT = 720
REFRESH_RATE = 60
VOICECHAT = 1
WAITFORVSYNC = 0
MAX_FRAME_RATE = 0
WINDOWED_BORDERLESS = 0
STRAND_BASED_HAIR = 1
USE_GOAL_NETS_3D = -1
NIS_AT_FULL_FPS = 0
CROWD_QUALITY = 3
GRASS_QUALITY = 3
DYNAMIC_RESOLUTION = 0
MOTION_BLUR = 0
CLOTH_QUALITY = 3
DYNAMIC_AO_QUALITY = 3
RESOLUTION_FOR_DISPLAY_MODE_LIST = 0_125830200|1_125830200|2_125830200|
I lowered the settings but didn't work.. The refresh rate remains on 60 HZ no matter what. My monitor is 100 HZ
Driver & Software Behavior :
I reinstalled the whole windows Full Fresh.. Formatted everything. Didnt work
Didn't try resizable Bar.
Troubleshooting Attempts :
No other Games doesn't show this kind of black screen. But Marvel's Spiderman 2 stutters when Ray Tracing turned On..I get it cause I have RYZEN 5 5600x its a pretty low tier cpu..That doesn't bother me
No ...no in game overlay is turned on
Optional Diagnostic Steps :
I tried playing in low Resolution but didn't work..
However when I tried to play in 1600 x 1050 insted of 1920x1080 it did bypass the issue.. But the resolution looks awful.
My friend plays this game on Ryzen integrated graphics no issue at all. I upgraded my pc, before that I had an R9 380.. It ran on low settings but didn't show the black screen at all.
Earl_Intel
Moderador
1.725 Visualizações
Hello awladhossen28,
Thank you for the comprehensive details regarding your system, game configuration, and the troubleshooting steps you've taken.
I understand how frustrating this issue must be, especially after such extensive efforts on your end—including reinstalling Windows and adjusting graphical settings.
I’ll investigate this internally and analyze the information you’ve shared to better understand the black screen issue you're experiencing with FC 25.
I’ll keep you updated as soon as I have more insights.
Earl E.
awladhossen28
Principiante
1.645 Visualizações
Maximum Users Use Arc B580 with Ryzen 5 5600x in my opinion. Please optimize it for this cpu.
Ernesto_C_Intel1
Moderador
1.330 Visualizações
Hi @awladhossen28
Thank you for sharing your feedback. I'm currently working to isolate the issue that you've encountered.
I'll provide you an update as soon as possible.
Ernesto C.
RandyT_Intel
Moderador
1.125 Visualizações
Hi @awladhossen28
I am reaching out to assist you with the issue you encountered while playing the game. To better understand the problem, could you please clarify whether you noticed any dot artifacts during gameplay or if the game stopped proceeding after halftime, resulting in a black screen?
To help resolve the issue, I recommend installing the latest graphics driver version 32.0.101.6972 (Latest). This update may address any compatibility or performance issues you are experiencing.
Additionally, I would appreciate it if you could provide me with the application and system event viewer logs from your system. These logs will help me identify any error messages that occurred while playing the game. Please follow the steps below to generate and send me the logs:
Application Event Viewer Log:
  1. Right-click on the Start Button.
  2. Click on Event Viewer.
  3. Click on the chevron next to Windows Logs.
  4. Right-click on Application and select "Save All Events As."
  5. Save the file and send me a copy.
  6. Please indicate the timestamp of the crash.
System Event Viewer Log:
  4. Right-click on System and select "Save All Events As."
Your cooperation in providing these details will greatly assist me in diagnosing and resolving the issue. If you have any questions or need further assistance, please do not hesitate to reach out.
Randy T.
Wizhhh
Principiante
1.069 Visualizações
Same happened here.. B580 LE.. Black Screen bug when half time / after match / loading to main menu.. So randomly but its there.. And also game performance without resizeable bar really bad in FC 25..
i set NO resize able bar + setting fc25.exe run compatibility windows 8 + play offline pressing X to cancel connecting ea server right before entering main menu. play in career mode more than couple of hours, finish youth tournament many times,  enter interview section, no blackscreen at all.
Please intel read this.
RandyT_Intel
Moderador
1.002 Visualizações
@Wizhhh To help us keep our responses organized and ensure we address your concern efficiently, we kindly ask that you submit a separate ticket or start a new thread for this issue. This will allow us to track and respond to your request more effectively.
RandyT_Intel
Moderador
882 Visualizações
Hi @awladhossen28
Just checking in on my request logs regarding your concern. Have you had a chance to review it? If you need more information or have any questions, feel free to reach out. I'm here to help!
Randy T.
awladhossen28
Principiante
857 Visualizações
Hi sorry for late reply.. Following this problem I reinstalled the game again and again.. So at the 4th time while playing at the lowest possible settings this problem had miraculously eradicated.. I have no idea how and why it worked.. I can Play the game without any complications. Previously i tested all the settings but no outcome.. All of a sudden it works!
RandyT_Intel
Moderador
716 Visualizações
Hi @awladhossen28
Thank you for the update, and no worries about the delay.
I'm glad to hear that the issue has been resolved after reinstalling the game and adjusting the settings. Since the problem was resolved when playing at the lowest possible settings, I’ll go ahead and mark this case as closed.
However, to help other users who might encounter a similar issue, could you kindly share the specific game settings you used when the issue was resolved? Even though the fix seemed spontaneous, having a reference to your configuration could be valuable for troubleshooting in the future.
Randy T.
Responder
