Intel® ARC™ Graphics
3294 Discussions
Fixed high temperature Intel Arc A770, and also give a little tips for future driver improvements fa
addelucas123
New Contributor II
!Good morning!
I'm David, I'm here to say that the high temperature is already solved, okay, I'll tell you a little above, I saw that before the temperature reached 77 to 79 degrees, but now it reaches 74 and 75 degrees with the Intel Arc A770 graphics card, Good, Well, I want you to be responsible for improving the curve just a little bit. Let's see if you can get 70 to 73 degrees. If not, then 71 to 73 degrees. That is, when it reaches a temperature of 70 degrees, the RPM starts working. of the GPU 2050 and 2100 RPM, so that it drops 3 degrees Celsius. Currently I have it automatic, but it would be appreciated if the curve improved a little. And I say that it is solved does not mean that the drivers have improved, no, the issue of high temperature and air flow thanks to the fact that I have organized the cables, so that it has greater optimality and fluidity, and it cannot be improved any further, that is, if or if you should correct it with an update as I told you, example triple AAA games which requires a lot, it must be running at 70 to 73 degrees Celsius for the best and optimal performance, at 75 degrees I see well, but the lower the better, then when the computer turns on we know that the fans will not work until it reaches 46 and 47 degrees is fine, well I would like it to start working at 40 and 43 degrees Celsius with a revolution of 700 to 800 RPM, and triple AAA games as I told you or with ray tracing that works from 2050 to 2100 RPM to reach 70 at 73 degrees Celsius with peak, Now I have it automatic and it reaches 1998 and 2000 RPM reaching 74 and 75 degrees Celsius all at maximum with the ultra graphics plus RT Ray traces 4 hours, well if you improve a little the curve just a little low I am satisfied with 3 to 5 degrees Celsius, but let it be 100% that you are going to improve that and nothing more,
greetings and hugs
RamyerM_Intel
Hello addelucas123,
I appreciate your desire to reduce the temperature of your graphics card. Rest assured that the maximum temperature is 90 C and anything lower than this is within the hardware specifications and will not have any negative impact on the product's performance and lifespan.
If there is no other comment I'll proceed to close this thread. Thank you for taking the time to voice your feedback to us.
Ramyer M.
