Intel® ARC™ Graphics
3395 Discussions
Game Crashing (Gears 5)
gasoline
AMD Ryzen™ 7 7700X Desktop Processor (Integrated graphics core is disabled in BIOS)
VGA ASRock Intel Arc B580 Steel Legend 12GB OC (BIOS Version 23.0.1051) Resizable BAR Enabled
Motherboards MAG B650M MORTAR WIFI (BIOS Version 7D76vAK) AGESA PI-1.2.0.3a Patch A
Ram DDR5-6000Mhz EXPO profile 2*16Gb(32Gb) Kingston FURY
SSD Samsung 980pro 1Tb + SSD Samsung PM9A1 1Tb
Power Supply Super Flower Leadex III Gold ARGB PRO 650W V2.0 [SF-650F14RG V2.0]
Monitor ACER XV272U Vbmiiprzx 2560x1440 170Hz DisplayPort cable connection
Windows 11 Pro x64 24H2 BILD: 26100.3624
Intel® Graphics Driver 32.0.101.6734 (WHQL Certified)
The cleaning was done using DDU v18.1.1.0 (Safe mode)
AMD Chipset Drivers Revision Number 7.02.13.148
Game:
Gears 5 (Purchased on Steam)
Gears 5:
It was up to Chapter 4, Act 2, everything was fine and the game didn't crash, only there were a couple of instances with FPS drops to 30 frames.
I tried different graphics settings in GEARS 5, the result is always the same, freezing with stuck sound, with the appearance of this message with the error code GW502.
But sometimes the monitor turns off completely and the computer doesn't respond at all, only holding the power button for a long time helps.
VonM_Intel
Hi, gasoline.
Thank you for posting in our Community and for providing such a detailed overview of your system configuration and the issue you're encountering with Gears 5. I appreciate the time and effort you've invested in your troubleshooting, and the information you've shared will greatly assist in our investigation.
However, I’ve sent you an email regarding this matter. If it’s not visible in your main inbox, please kindly check your spam or junk folder, as it may have been filtered there
Have a nice day!
Von M.
VonM_Intel
Hello, gasoline.
Von M.
gasoline
I did a full disk cleanup and a clean installation of licensed Windows 11 Pro. BILD: 26100.3915
This did not help.
gasoline
Hello! Instead of helping, they ask me my country of residence.
This did not help.
When loading the game to the control point via Steam, the result is the same.
RandyT_Intel
Hi @gasoline,
Please respond to the email sent by my colleague. We want to ensure we avoid duplicate cases and focus on resolving this issue efficiently, preventing any repeated steps. Kindly reply to the email with the requested information, and we will proceed accordingly.
Randy T.
VonM_Intel
Hello, gasoline.
I’ve sent you an email regarding this matter. If it’s not visible in your main inbox, please kindly check your spam or junk folder, as it may have been filtered there. Just following up to see if you had a chance to review my previous email. Please don’t hesitate to reach out if you need any further information or support. I'm here to assist.
Von M.
gasoline
I see an email in my mailbox. There are no solutions to my problems. What should I answer yet, I don't understand?
VonM_Intel
Hello, gasoline.
I apologize for any confusion that may have arisen from our previous correspondence. I understand that your concerns may not have been fully addressed, and I’m committed to supporting you with a clear and effective resolution. To move forward, I’ve sent a follow-up email with further details. Kindly review and respond at your earliest convenience so we can proceed with the appropriate next steps.
Thank you.
Von M.
gasoline
Hello!
I don't care which channel to use to solve problems, the main thing is to solve them.
VonM_Intel
Hello, gasoline.
Thank you for your message. I completely understood, and we share your goal of resolving the issue promptly.
To ensure all important details are addressed, I’ve sent you an email with key information. Kindly check your inbox at your earliest convenience, as your response there will help us move forward more effectively
Von M.
gasoline
Dear friend
From the very beginning I wrote to this forum, describing the problems with these games, I want to help you solve these problems, so that people are not afraid to buy Intel video cards, because this is a good purchase for this price.
But I faced the fact that no one answered me here for a long time, so I wrote directly to Intel and only after that the first answer came.
A whole month has already passed, but these problems have not been solved, I understand that you have a lot of work with drivers, they need to be rewritten for new games.
I also provided all the requested information on this error, showed screenshots and videos, sent diagnostic files and fully described my entire system, down to the version of each driver.
But. I did not see that someone is busy with my problems with the video card, I just get the same type of answers, wait, send me your country of residence, give me a phone number, etc. .. .
We will not be able to contact you with all our desires, except by mail and this forum.
I just wanted to know if anyone is busy solving these problems, and if you were able to reproduce them?
I don't want to participate in any statistical surveys, etc.
I followed all your recommendations, including a clean installation of Windows........
But everything is the same as before, one game crashes in the same place, another lags.
VonM_Intel
Hello, gasoline.
Thank you for your detailed follow-up and for your continued patience throughout this process. First and foremost, we want to sincerely acknowledge and appreciate the time and effort you’ve invested in documenting your experience, testing multiple solutions, and providing detailed system diagnostics. Your commitment not only demonstrates technical diligence but also a genuine desire to see Intel’s GPU platform succeed, and for that, we’re truly grateful. I deeply regret that your initial outreach did not receive the timely and focused attention it deserved. You're right to expect better communication and more meaningful engagement, especially after taking all the recommended steps and supplying complete technical data. Yes, we are actively investigating the issues you reported.
In the meantime, I will need to do further research on this matter and post the response on this thread once available.
Von M.
VonM_Intel
Hello, gasoline.
I have not heard back from you, so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
gasoline
Good day!
I did everything as you said, the problem with this game is the same, it first freezes, and then crashes with error GW502.
With these driver versions, the problems still persist:
Intel Graphics Drivers 101.6790 WHQL
Intel Graphics Drivers 101.6795 Beta
gasoline
Hello!
New driver gfx_win_101.6874WHQL has been released, I removed the previous driver using DDU v18.1.1.3, the situation has not changed.
gasoline
The problem is still not solved, I can't continue the game, I'm stuck at the same place.
Here are the driver versions I tried:
gfx_win_101.6876
gfx_win_101.6877
gfx_win_101.6881
