I am experiencing graphical corruption in Star Wars Battlefront 2, there are flashing squares all over the models. This happens no matter what settings I use. My old RTX2080ti and GTX1650 did not have these issues.
The game is obtained through the EA app on my Asrock Challenger OC ARC B580 running the latest drivers (32.0.101.6913) obtained through the Intel Command Center. Asrock doesn't have its own drivers.
I have added a short video that showcases the issue (in the main menu) and settings. All you have to do is start the game and the issue is already visible on the main menu and carries over into gameplay. I also added the SSU from this system.
Another issue with this game is that HDR doesn't work properly (like many other games) and but just activates Windows AutoHDR. You guys keep saying that it is an issue with the game not being compatible with the way you guys do HDR, but let me tell you this... if nVIDIA and AMD work correctly, YOU are the problem, not the game and you should actually make your drivers compatible, NOT the other way around.
Do NOT tell me my platform is the problem as my platform supports ReBAR and everything needed to run the ARC B580. Other games do work correctly and have great performance.
Hello Kyrandar,
It looks like you’ve already reached out to us through another channel, and I can see that your concern is currently being looked into. To help avoid any confusion or duplication, please continue following up through the original case. I’ll go ahead and close this inquiry for now. If you need anything else, feel free to reach out again.
Best regards
Jed G.
