Intel® ARC™ Graphics
3318 Discusiones
High idle temps and DX11 issue [a750]
Nes_
Principiante
4.582 Vistas
I got an ASRock a750 gpu. I find the idle temperature is unusually high, sitting around 60+ degrees. May I know it is a normal state?
Also, when using an Android emulator for a long period of time, e.g. 4 hours. When I launch another emulator or a game (e.g. LOL), it will show DX11 crash or no memory is able to be allocated. I hope someone can help me with the above issues. Thanks in advance
0 kudos
5 Respuestas
Andres_Intel
Empleados
4.520 Vistas
Hello Nes_,
Thank you for posting on the Intel communities. I am sorry to hear that you are having overheating and crashing issues with your Intel® Arc™ A750 Graphics, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
Andres P.
Nes_
Principiante
4.471 Vistas
Yes, the resizable Bar is enabled.
It started when I bought the card.
For the DX11 issue, it happens only when using Android emulator, which I am not using atm. I will provide it when it happens.
See the attached documents for the report.
Andres_Intel
Empleados
4.467 Vistas
Hello Nes_,
Thank you for your response, all the information provided has been really helpful.
The maximum temperature supported by the Intel® Arc™ A750 Graphics is 90 Celsius, when the graphics card reaches that temperature the fans should turn on and the temperature decreases. If the graphics card has a different behavior that means that probably there is an issue. Let me know if the behavior is different.
I will wait for you to attach the screenshots of the error message DX11 crash or no memory is able to be allocated, for me to have a better understanding of the issue and start with the troubleshooting.
Andres P.
Andres_Intel
Empleados
4.338 Vistas
Hello Nes_,
Andres P.
Hugo_Intel
Empleados
4.276 Vistas
Hello Nes_
I hope you are doing fine.
We have not heard back from you. So I will close this thread. If you are still experiencing errors when using an Android emulator submit a new question, as this thread will no longer be monitored.
Hugo O.
Responder
