Intel® ARC™ Graphics
3359 Discussions
Hotkey rotation fails
DaveE43
Hello, I would like to request help.
It is pretty simple: I enabled system hotkeys in the Graphics Command Center and then a notificacion appears saying "hotkey action failed" when I try Ctrl+Alt+ left/down/right.
Any way I can solve this? excuse the language UI being in spanish.
Jean_Intel
Hello DaveE43,
Thank you for posting on the Intel️® communities. We would be more than glad to help you.
It is important to mention that Original equipment manufacturers (OEM) can disable certain hot-key functions. Also, you may not be able to select a new hotkey combination if it is already being used for another application.
Jean O.
Jean_Intel
Hello DaveE43,
We hope you are doing fine.
Best regards.
Jean O.
