Intel® ARC™ Graphics
3335 Discussions
How to enabling OpenCL with intel Arc 770 in Ubuntu
TimWe
I installed the
install "intel-opencl-icd" in ubuntu 22.04 and "clinfo"- output is following:
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) Intel(R) OpenCL HD Graphics
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) Success [INTEL]
clCreateContext(NULL, ...) [default] Success [INTEL]
clCreateContext(NULL, ...) [other] Success [INTEL]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) Success (1)
Platform Name Intel(R) OpenCL HD Graphics
Device Name Intel(R) Graphics [0x5690]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) Success (1)
ICD loader properties
ICD loader Name OpenCL ICD Loader
ICD loader Vendor OCL Icd free software
ICD loader Version 2.2.14
ICD loader Profile OpenCL 3.0
I think OpenCL is active? But what means "No devices fund in platform"?
Ineed OpenCL especially for "Darktable"
"darktable-cltest"  -output is following:
darktable 4.6.0
Copyright (C) 2012-2023 Johannes Hanika and other contributors.
Compile options:
Bit depth -> 64 bit
Debug -> DISABLED
SSE2 optimizations -> ENABLED
OpenMP -> ENABLED
OpenCL -> ENABLED
Lua -> ENABLED - API version 9.2.0
Colord -> ENABLED
gPhoto2 -> ENABLED
GMIC -> ENABLED - Compressed LUTs are supported
GraphicsMagick -> ENABLED
ImageMagick -> DISABLED
libavif -> ENABLED
libheif -> ENABLED
libjxl -> DISABLED
OpenJPEG -> ENABLED
OpenEXR -> ENABLED
WebP -> ENABLED
See https://www.darktable.org/resources/ for detailed documentation.
See https://github.com/darktable-org/darktable/issues/new/choose to report bugs.
0,0122 [dt_get_sysresource_level] switched to 2 as `large'
0,0122 total mem: 63875MB
0,0122 mipmap cache: 7984MB
0,0122 available mem: 43664MB
0,0122 singlebuff: 998MB
0.0142 [opencl_init] opencl library 'libOpenCL' found on your system and loaded, preference 'default path'
0.0251 [opencl_init] found 2 platforms
0.0251 [opencl_init] detected wrong OpenCL platforms setup
0.0251 [opencl_init] FINALLY: opencl is NOT AVAILABLE and NOT ENABLED.
darktable founds a "libOpenCL" but whats the meaning of wrong platformsetup? How can I setup right?
NormanS_Intel
Hello TimWe,
Thank you for posting in the community!
I will discuss this case with our team to identify the root cause of the issue and will provide an update in this thread as soon as it is available.
Norman S.
NormanS_Intel
Hello TimWe,
Thank you for your patience. We have reviewed your concern, but we need to gather more information to better understand and identify the root cause. Could you please provide the following details:
1. Can you share the exact link to the Darktable app you are using?
2. Provide the Intel® System Support Utility Logs of your computer. This will help us check your system configuration in depth. You can check our Help Guide for the Intel® System Support Utility, look for Linux, and follow the steps to obtain the logs. Once you have the logs, kindly attach them to this thread.
3. Has this setup ever worked before, or is this the first time you are setting it up?
Norman S.
NormanS_Intel
Hello TimWe,
Norman S.
