Hi Good Afternoon
I have an
arc B580
i5 12400f
b660M-pro
32gb RAM
graphics driver in the latest stable version
I'm having performance issues while recording on discord. I would like to know if there is anything I can do to improve this.
链接已复制
Hello AsterCrash,
It appears that you are having issues while recording on Discord and for me to assist you effectively, please supply the information below.
1. Was this working fine before?
2. Is the issue isolated to Discord?
3. Have you tried using another recording software?
4. If possible, kindly share a short video clip of the issue.
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
I hope to hear from you soon.
Best regards
Jed G.
apparently only on discord I tested the windows one and it was normal attached to the SSU
Hi I am a new user of B580 Arc I use Discord a lot, When I start streaming STALKER 2 game in Discord my fps and performance drops, from time to time in different ways, there was a drop from 60 fps to 30, now in the video I attached to this report I got a drop from 66 to 55 fps, if I get a more significant drop in performance - I will add another video separately with new results of performance drops https://youtube.com/shorts/66dXsCbTrE4?feature=share
I've tried different modes of broadcasting in Discord, unfortunately they don't bring any improvements. In the video to this answer - discord settings are attached to the screenshot
Hello AsterCrash,
Thank you for this. Kindly also gather CapFrameX data and please ensure to record at least 3-5 minutes of use so we can compare the values that you are getting on our end.
Hi @PsiHoloG,
It appears that you're also experiencing issues with Discord. For us to address your concern and to avoid any confusion, please create a separate thread and one of the support will be helping you.
Best regards
Jed G.
Hello AsterCrash,
I appreciate you for sharing the SSU report but for me to further troubleshoot the issue, please generate CapFrameX data and ensure to record at least 3 minutes of use.
Best regards
Jed G.
Hi AsterCrash,
I'm following up with regards to the information we requested. Please share this at your earliest convenience so we can further investigate.
Jed G.
Hello AsterCrash,
Thank you once again for your continued effort and cooperation throughout this process—it is truly appreciated.
To help us better understand and address the issue you're experiencing, we kindly ask that you share a short video clip demonstrating the problem. This will allow us to observe the behavior directly and provide more accurate guidance moving forward.
Best regards
Jed G.
Hi AsterCrash,
I'm just following up with regards to the information that I previously requested that will help with our investigation.
Jed G.
Hello AsterCrash,
Jed G.
