Intel® ARC™ Graphics
3278 Discussions
INTEL ARC A 750 GPU CAN NOT OPEN XPLANE-12
Rutkay
 Hello I am having this issue can not open Xplane-12
system Amd R5 5600
gpu Intel Arc A750
Ernesto_C_Intel1
Hello Rutkay,
Thanks for your patience. The issue you've reported has already been addressed in X-Plane 12 Beta version 12.1.0.
Update to the BETA version can be found here: https://www.x-plane.com/kb/using-x-plane-betas/
Please note that the fix is not available in the public version of X-Plane 12.
Installing the Intel® Arc™ & Iris® Xe Graphics - Windows* version 101.5186 or newer includes performance improvements for X-Plane 12.
You may download the driver at https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Ernesto C.
Jean_Intel
Hello Rutkay
Thank you for reaching out to the Intel Communities for assistance with your XPLANE-12 game. We would be happy to help you resolve this issue. We would like to request that you provide us with a system report generated using the Intel® System Support Utility (Intel® SSU). This will allow us to investigate further and provide you with the appropriate support:
  • Download the Intel SSU
  • Open the application and click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
  • To save your scan: click on "Next"; then "Save."
Best regards
Jean O.
Rutkay
Hello Jean;
This is the SSU report as you ask.
Best regards.
Jean_Intel
Hello Rutkay,
Thank you for the information provided. We would like to let you know that Intel is currently investigating this issue. Unfortunately, we can't commit to an estimated time or update about this matter, nevertheless, rest assured that we are looking into this matter. We will continue to investigate this matter internally, and we will post back as soon as we have more details.
Best regard
Jean O.
Rutkay
Hello Jean;
Any progress about this issue?
Rutkay
Hi any progress about this issue?
Rutkay
Hi Jean ;
Thank you for the fast replay. I will be waiting for the solution. Thanks for everyone who is into this issue.
Best regards.
Ernesto_C_Intel1
Hello Rutkay,
Ernesto C.
Ernesto_C_Intel1
Hello Rutkay,
Kindly advise if you still experience the issue after implementing the fix I've previously suggested.
Ernesto C.
Ernesto_C_Intel1
Hello Rutkay,
This would be my final follow-up. Since we have not received any response from you, I'll go ahead and close this case.
If you require assistance or have questions, please do not hesitate to contact us again.
Ernesto C.
