Intel® ARC™ Graphics
3344 Discussions
Intel A770 Discord Stream
Honnop
When trying to stream a game or even stream my normal screen to a Discord call, Discord crashes nearly instantly, is this a Discord problem or can I fix this ?
Thank you in advance
VonM_Intel
Hi, Honnop.
Thank you for posting in our Community.
Streaming issues with Discord are not uncommon and can arise from a variety of sources. Could you verify if Discord was operating smoothly before this problem emerged? Also, have you made any recent changes or tweaks to your settings? Ensuring that your graphics driver is up-to-date is crucial; you can find the latest update here. Additionally, check if you're running the latest version of Discord, as an outdated application can often lead to crashes. Furthermore, updating your motherboard's firmware could potentially fix the issue.
To delve deeper, I'd like to verify specific details such as your processor, graphics card model, drivers, and any system errors. The Intel SSU tool is designed to collect such information about your system's configuration, which could be instrumental in diagnosing the root cause of this issue.
Von M.
VonM_Intel
Hi, Honnop.
I trust you're doing well.
I have not heard back from you, we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
