Intel® ARC™ Graphics
3334 Discussions
Sudden usage and fps drop in cs2 with arc a770 16gb
7wi1i9h7
When I start playing cs2 the frames seem to be stable sitting around 250-350, but after a few minutes the gpu usage drops to 40-60% and the fps drops as well ( around 100-180). rebar is enabled and tried using vulkan as well but in vain.
andreas282
Hello, 7wi1i9h7
I think we have similar issues.
This is my thread : https://community.intel.com/t5/Intel-ARC-Graphics/Intel-ARC-A380-Low-Profile-Unstable-FPS-on-CSGO2-CS2/m-p/1584980#M13347
What system are you using such as CPU, motherboard and RAM?
Andreas
7wi1i9h7
hey andreas282,
my cpu is ryzen 5 7500f, motherboard is msi pro b650m-b and ram is corsair vengeance 6000mhz running at 4800mhz.
RamyerM_Intel
Hello 7wi1i9h7
Thank you for posting in the communities. May I please know if there are specific scenarios in the game where these fps drops happen? I also appreciate that you have engaged with one of our community members. I do want to further check your configuration to see if it is in optimal configuration. Kindly share with us your SSU logs. Additionally, have you already tried different arc drivers on your system? If you do, what versions are they? I will be waiting for your reply.
Ramyer M.
RamyerM_Intel
Hello 7wi1i9h7,
I am just checking for the logs of your system. Kindly please let me know about this information so we can identify the next steps that needs to be taken to solve this issue. I will be waiting for your reply.
Ramyer M.
RamyerM_Intel
Hello 7wi1i9h7,
I hope  everything is alright in your end. As we have not heard a response from you in the past days, I will be closing this case. Please create a new post in case you need further assistance as this thread will no longer be monitored.
Ramyer M.
