Intel® ARC™ Graphics
3289 Discussions
Intel ARC A750/Problem with games: Tinykin, Metal Slug XX, The King of Fighters XIV, Resident Evil 5
Monty
Previously tried to resolve mi issues using Intel's Discord support but no one solved my problem, I hope to receive help using this forum.
Hardware:
- CPU: Ryzen 3700X
- GPU: ARC A750
- MB: ASRock B450M Steel Legend (Bios Updated)
- RAM: 32GB
Actually I have some problems with the Next games:
-Tinykin (DX11) : During gameplay is not possible to play because the screen become white-like and different artifacts appears.
-Resident Evil 5 (DX9): game doesn't start.
-Metal Slug XX (OpenGL): Graphical artifacts, poor colors and the most part become black, lines appears rounded the different sprites.
-The King of Fighters XIV (OpenGL): Graphical artifacts, poor colors and the most part become black, lines appears rounded the different sprites.
Jose_Intel
Hello Monty
Thank you for the reports.
We are going to check the issue internally, as soon as we have an update we will let you know.
Jose B.
Jose_Intel
Hello @Monty
Thank you for posting on the Intel️® communities.
I am sorry to hear that you have problems with Intel® Arc™ A750 Graphics, and I’ll be more than happy to help you.
In order to have better control and keep everything organized, we will focus on Resident Evil 5. Could you please open a new thread for every game that is not working properly?
Please answer the following:
·      Was the game working before or it never did?
·      What is the game distribution service?
·      Is Resizable BAR enabled?
·      Is there any error code? You can attach screenshots.
·      Have you tried older driver versions?
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Then, please generate and attach the Report for Intel® Intel Graphics Command Center
Jose B.
Monty
Thank you,
About Resident evil 5
        Never did it.
       Steam
       YES
       No errors, the game just cant be launched
       Yeah with All.
Jose_Intel
Hello Monty
Thank you for that information.
Please do not forget to attach the reports from Intel® System Support Utility for Windows and Intel® Intel Graphics Command Center
Jose B.
Monty
Hello Jose,
I attached the files.
Jose_Intel
Hello Monty
Jose B.
Monty
Hello jose,
Thank you very much.
Have a nice day.
Monty
Hello Jose.
 I Installed the new driver (31.0.101.4577) the game works correctly.
Jose_Intel
Hello Monty
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel.
Jose B.
