Hi, I bought the intel arc a750 gpu quite a few months ago. From my first start-up, until now, I'm not getting even close to the exact performance as i should be getting according to my system. Let me elaborate a bit.
Here's my system:-
- Ryzen 5 5600G
- msi mag b550-m mortar max wifi
- 2x8GB of 3200mhz ram
- os: windows 11 23h2
- antec csk 650w power supply
Now, I have the RE-BAR and xmp on. I saw a benchmark on youtube where the creator had the exact same primary specs as me; yet he was getting much better performance. Here's the link < https://youtu.be/PkaSZwcia_s?si=Z4w-NEGJ3_7PkF2c > In my case, i was getting around 45fps in gta v, quite lower than the one in this yt video. I've tried it with other games as well, and the result was the same, very low performance than expected. I've been having this problem since quite sometime now, a few driver updates came and i updated my driver version each time up until now, but it still didn't work. now, i have the latest driver as of now (version 101.5234).
連結已複製
Hello ItzAlif,
To improve the performance of your graphics card, please follow the troubleshooting procedures provided at the link below. In addition, I checked that the most recent driver for the Arc A750 is already 31.0.101.5333.
- Lag and Low FPS Performance while Playing Games Using Intel® Arc™ Graphics
- Performance Issues Encountered While Gaming with Intel® Graphics
Thank you, and have a great day ahead!
Carmona A.
Hello.
I apologize for replying late. I've followed and confirmed each step you've provided. However, the issue still persists without any notable improvements. My current motherboard bios is upto date 'till now and the current graphics driver version is 5333 as you've mentioned. I'd be glad to know if I could do anything else to really get rid of this issue. Thank you!
Hello ItzAlif,
We are checking in with you on the Intel arc A750 low-performance issue to see if you have already performed the troubleshooting steps that we have provided or if you have any additional queries. Please know that we would be happy to assist you if you have any.
Thank you, and have a great day!
Carmona A.
As I've said earlier, I performed each necessary step including updating the driver and bios, turning on xmp (to 3200mhz) and re-bar. Yet, the problem still persists, still getting low performance. Apart from that, I don't have any additional queries right now. Thank you.
Hello ItzAlif,
Thank you so much for the response.
Kindly provide us with your SSU to help me further analyse important details on your system, such as the OS build number, graphics driver version, errors logged in the system, etc. To generate the SSU report, please refer to the article How to Get the Intel® System Support Utility Logs on Windows. Please send us the generated SSU.txt file, as I will raise our issue with our engineers.
Carmona A.
Hello ItzAlif,
Thank you so much for proving us your SSU.
We will do further research on this matter and post the response on this thread once it is available.
Have a fantastic day, and thank you very much for your patience and understanding!
Carmona A.
Hello ItzAlif,
Thank you for patiently waiting for our response.
We'd like to get more information from you to better drill down on the issue:
- When you say you are getting 45 fps, is this consistent across gameplay or just specific areas of the game (e.g., a crowded area, etc.)?
- Please provide screenshots or describe the graphics settings you are using in the game. (e.g., resolution; vsync setting; is MSAA enabled, etc.)
I hope to hear from you soon.
Carmona A.
Thank you for reaching out!
I have actually uninstalled GTAV since I can't seem to enjoy it pretty much.
Now, I've got the witcher 3. I'm sending in some screenshots of during the gameplay. I've looked up some benchmarks of another system with almost the same specs and it was getting 65+ fps on ultra+. And here, I was getting around 55-60 while standing still and 37-50 while going to places (i.e. while riding the horse). Sorry, Couldn't check if the amount of crowd or grass affected my fps.
Also sending a couple of screenshots of an elden ring gameplay. In this case, the fps was around 35-50ish, still way below the benchmark I saw.
Thank you for your support.
Hope to hear from you soon!
Hello ItzAlif,
Thank you so much for the response and for the information that you have shared.
I will now raise the issue again with our engineers using the information that you have provided, then post the response on this thread again once it is available.
Thank you very much for your patience and understanding!
Carmona A.
Hello ItzAlif,
Thank you so much for patiently waiting on our response.
We have noticed in one of your settings in the screenshots that you shared that you have maxed out Nvidia Hairworks, which can introduce a significant performance drop.
In regards to that, please see the article related to this, but for a different game, the effects will be the same. "Enabling TressFX* or HairWorks* Functionality Affects the Performance of Tomb Raider (2013)".
It is suggested that you turn it off and check the performance again.
By the way, we have our new released driver, which is 101.5379; please try it and check if the performance will enhance.
Furthermore, may we know what distribution platform are you using with Witcher 3? (e.g., Steam, GOG, Epic, etc.) and also what DX version are you playing Witcher 3? Have you tried both DX 11 and DX 12?
We look forward to your response!
Carmona A.
Hello.
I've updated my driver to 101.5379. After the update, my other games (i.e. valorant, horizon zero dawn) have reduced performances. In case of valorant, it's now a bit stuttery and in case of hzd, it just crashes after i go beyond an area i guess. On the previous driver version and in this one as well, if I look at devi's grief in hzd, the fps drops to 30-40 and if i look away, it goes up to 60ish.
After you've said so, I've tried dx12 in the witcher 3 just a while ago and it was worse than dx11. It was really stuttery and also crashed after a minute or two. Also tried turning off hairworks but didn't see much difference. And I've got witcher 3 from fitgirl repacks.
Should i revert back to driver version 5333? please let me know since this version is more stuttery than the one before.
Thank you for your support. Hope to hear from you soon.
Hello ItzAlif,
Please allow me to raise the result of the troubleshooting steps that we have tried with our engineers so they can further investigate the issue. Then, once I have the update, I'll again post it on this thread.
In the meantime, you may revert back to 5333 or try our new release driver again, which is 31.0.101.5382
Thank you so much for your understanding, and have a great day ahead!
Carmona A.
Hello ItzAlif,
Please follow the provided troubleshooting steps below for a possible solution to our issue:
- Carry out a clean installation of the latest graphics driver using DDU to remove any previous drivers completely.
- Regarding the game crashing, it would be helpful to ask if the customer receives any error messages upon crashing. If possible, a screen recording or screenshot of the issue would greatly assist us in replicating and diagnosing the problem. Additionally, inform the customer that our tests with Valorant using driver version 31.0.101.5379 did not result in any stuttering issues.
- Enable the optimizations for windowed games. For reference, you can check out this Optimizations for Windowed Games in Windows 11 article from Microsoft.
Furthermore, we also wanted to share with you the following articles, as they are relevant and offer further recommendations for optimizing performance in other games.
- Valorant* stutters and has low FPS (frames per second) with Intel® ArcTM Graphics
- Horizon: Zero Dawn* Poor Performance with Intel® ArcTM Graphics
Carmona A.
Hello ItzAlif,
We are checking in with you to know if you have already performed the troubleshooting steps that we have provided or if you have any additional queries. Please know that we would be happy to assist you if you have any.
Carmona A.
Hello ItzAlif,
We have not heard back from you, so we will close this enquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Thank you, and have a great day ahead.
Carmona A.
I have the same Motherboard and also issues with a A380.
In Furmark I only get around 30 FPS where it should be around 42 FPS. : https://www.gpumagick.com/scores/845274
Did you find a solution with your A750?
Jakob
SSU:
# SSU Scan Information
Scan Info:
Version:"3.0.0.2"
Date:"02/23/2025"
Time:"00:00:28.0159140"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Micro-Star International Co., Ltd."
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends International, LLC. 1.L1 , 04/09/2024 12:00 am"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"AMD Ryzen 5 5600X 6-Core Processor , AuthenticAMD"
Secure Boot State:"Off"
SMBIOS Version:"2.8"
Sound Card:"USB Audio Device"
Sound Card:"Realtek High Definition Audio"
System Manufacturer:"Micro-Star International Co., Ltd."
System Model:"MS-7C94"
System SKU:"To be filled by O.E.M."
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "Intel(R) Arc(TM) A380 Graphics"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"2.00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Arc(TM) A380 Graphics"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Arc+A380+Graphics"
CoInstallers:"oem44.inf,DG2_Client_FWU_wNext,Internal,Intel(R) Arc(TM) A380 Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmdnd64.sys"
Driver Date:"02/04/2025 01:00 am"
Driver Path:"C:\WINDOWS\system32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4710909d97091293\igdkmdnd64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"32.0.101.6559"
INF:"oem44.inf"
INF Section:"DG2_Client_FWU_wNext"
Install Date:"Not Available"
Installed Drivers:"C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4710909d97091293\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4710909d97091293\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4710909d97091293\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4710909d97091293\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_56A5&SUBSYS_60041849&REV_05\6&2A11C331&0&00080019"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"59 Hz"
Refresh Rate - Maximum:"60 Hz"
Refresh Rate - Minimum:"30 Hz"
Resolution:"3840 X 2160"
Scan Mode:"Noninterlaced"
Service Name:"igfxnd"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) Arc(TM) A380 Graphics Family"
- "Memory"
Physical Memory (Available):"24.69 GB"
Physical Memory (Installed):"32 GB"
Physical Memory (Total):"31.93 GB"
- "P0 CHANNEL A"
Capacity:"16 GB"
Channel:"DIMM 1"
Configured Clock Speed:"3600 MHz"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"Not Available"
Manufacturer:"Unknown"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"F4-3600C16-16GVKC"
Serial Number:"00000000"
Status:"Not Available"
Type:"Not Available"
- "P0 CHANNEL B"
Capacity:"16 GB"
Channel:"DIMM 1"
Form Factor:"DIMM"
- "Motherboard"
BIOS:"1.L1, ALASKA - 1072009"
Caption:"Motherboard"
Chipset:"Not Available"
Date:"09/04/2024 02:00 am"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"ACPI\PNP0C01\C8"
Product:"MAG B550M MORTAR WIFI (MS-7C94)"
Serial Number:"REMOVED"
Status:"OK"
Version:"1.0"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
REMOVED
- "Intel(R) Wi-Fi 6 AX200 160MHz"
Access Point:
Authentication:
- "Caption":"Intel(R) Wi-Fi 6 AX200 160MHz"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Wi+Fi+6+AX200+160MHz"
Channel:
Cipher:
CoInstallers:"Not Available"
Connection Mode:
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"Netwtw10.sys"
Driver Date:"01/21/2024 12:00 am"
Driver Path:"C:\WINDOWS\system32\drivers\Netwtw10.sys"
Driver Provider:"Intel"
Driver Version:"23.30.0.6"
Index:"0000"
INF:"oem22.inf"
INF Section:"Install_GEN_QSR_CcP_200_AX_2x2_WinT"
Installed:"Yes"
IP Address:"Not Available"
IP Subnet:"Not Available"
Last Reset:"02/23/2025 08:49 pm"
MAC Address:"REMOVED"
Net Connection ID:"WiFi"
REMOVED
- "Operating System"
.Net Framework Version:"4.0,4.8"
Boot Device:"\Device\HarddiskVolume1"
Internet Browser:"Mozilla Firefox, Internet Explorer,11.1882, Microsoft Edge,133.0"
Locale:"United Kingdom"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 11 Pro"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"5.00 GB"
Physical Memory (Available):"24.72 GB"
System Directory:"C:\WINDOWS\system32"
Version:"10.0.26100 Build 26100"
Virtual Memory (Available):"27.57 GB"
Virtual Memory (Total):"36.93 GB"
Windows Directory:"C:\WINDOWS"
- "Installed Updates"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB5043113:"Security Update [9/6/2024]"
KB5048779:"Update [2/23/2025]"
KB5049622:"Update [2/23/2025]"
KB5050575:"Update [2/23/2025]"
KB5051987:"Security Update [2/23/2025]"
KB5052085:"Security Update [2/23/2025]"
- "Processor"
Not Available:
...#SSU#...
