Intel® ARC™ Graphics
3277 Discussions
Intel Arc B580 - Severe Freezing During Multitasking
Mookei
Switfishere have already posted the issue but was asked to make a new post.
Intel Arc B580 - Severe Freezing During Multitasking and Streaming - Intel Community
When I bought the Inter Arc B580 all was good until I switched to Windows 11. Then I noticed that any multitasking created stuttering and freezing for example I was playing a game and had a browser with youtube, tried both chrome and edge. The browers stuttered or some times freezed so I hade to close the browser and open it again. When I played the game and I tabbed out the game was stuttering.
After reading the post and troubleshooting from Swiftishere I disabled ReSize Bar and all seems fine. FPS in the game dropped but multitasking felt smooth.
I tried enabling ASPM as guided by Dhanniel and re-enabled ReSize Bar. And by enabling ASPM it seemed to be better but still not good, so going to disable ReSize Bar again until it's fixed.
Some of my hardware might be a bit old but I did not have the issue with Windows 10.
SSU log Attached
Br
Mookei
Mike_Intel
Hello Mookei,
  1. When did you start noticing the issue?
  2. Did you change any settings before the issue started?
  3. Are you using an Intel brand Arc B580?
  4. What is the specification of your Power Supply?
  5. What are the troubleshooting steps that you tried so far?
Michael L.
Mookei
Hi Michael,
About 6 weeks ago after I undated from Windows 10 to Windows 11. I did not feel this issue with Windows 10.
Upgraded to Windows 11
Yes
Corsairs RM750X
Reinstalled drivers and made sure that they where up to date but the only thing that have worked is as described shwiftishere's troubleshooting by disable Re-size bar. https://community.intel.com/t5/Intel-ARC-Graphics/Intel-Arc-B580-Severe-Freezing-During-Multitasking-and-Streaming/td-p/1690562
Mike_Intel
Hello Mookei,
Thank you for the update.
Please try to reinstall the driver using DDU methos for us to check if this is a driver issue. Kindly refer to the link below for the link of the DDU steps and link of the latest driver:
https://www.intel.com/content/www/us/en/support/articles/000091878/graphics.html
https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Once done and you are still having the same issue, please help generate the latest SSU logs of your system. Please refer to the link below for the steps:
Michael L.
Mookei
Hi Michael,
Reinstalling the driver using DDU method seemed to be the solution and I've reactivated Re-size. It seems to be much better so I will run it and get back it it stats to freeze again.
Thank you for your support!
Br
Mookei
Mike_Intel
Hello Mookei,
I am glad to hear that. Kindly update me again if you are not having the issue after your further test.
Please tell me if we can close this issue.
Michael L.
Mookei
Hi, Michael,
I've used it for 2 days now and there still is some freezing issue, a bit better after reinstalling the driver using DDU method but unfortunately still not good enough.
I also see that others have the same issue and an investigation have been started Intel Arc B580 - Severe Freezing During Multitasking and Streaming - Intel Community
Br
Mookei
FachryNugraha
Hi Michael
Please investigate this issue immediately
I’ve been waiting for answers
This is a big issue
Mookei also have mentioned the related post from swiftishere
Thankyou
Mike_Intel
Hello Mookei,
Michael L.
Mookei
Hi Michael,
I installed the new update 32.0.101.6881 yesterday and reinstalled the driver as well when doing the update and it's ok again.
I read the update release notes and saw "Visual corruptions may appear in certain scenarios with multiple application interactions."
But tbh I want a few days to verify that eveything is ok.
Br
Mookei
Mike_Intel
Hello Mookei,
This is a good development. I will give you few days to test it and send another follow up in case I don't get an update from you.
Michael L.
Mookei
Hi Michael,
After the update is see improvements and it works better, but still not 100%. But still good enought that I think we can close the ticket as I hope it will be improved in more updates. If note I will create a new ticket
FachryNugraha if you still have an issue after the update you should create a new ticket.
Br
Mookei
Mike_Intel
Hello Mookei,
Thank you for the update and I am glad to hear that.
Since you said we can close the case, I need to close this inquiry.
Michael L.
Mike_Intel
Hello Mookei,
By the way, before we close this request. Let me add more troubleshooting since I noticed this after reviewing the information that you sent.
You may consider performing a BIOS update, as the SSU logs indicate that the BIOS is outdated. Updating the BIOS can sometimes stabilize the system. Here is the link to download the latest BIOS of your motherboard: https://www.msi.com/Motherboard/Z590-PRO-WIFI/support
For more information about the graphics card, you can refer to our Intel® Arc™ Graphics – Desktop Quick Start Guide article. If you need additional assistance, please create a new thread, as we will not be able to monitor this thread once we close this inquiry.
Lastly, we are suggesting further troubleshooting because it is unusual for the system to freeze simply by disabling ReSize Bar, as this should not occur.
Michael L.
Mookei
Hi Michael,
Good eye! I thought I've updated it a year ago but apparently not so updated it now and it did approve the performance.
I've also read that this is now a known issue so hope that the future updates will improve the performance more. But for now it's a big improvement sicne the issue started so thank you so much for your support!
Br
Mookei
Mike_Intel
Hello Mookei,
I am just sending a follow up to check if you were able to review my last post.
Michael L.
Mike_Intel
Hello Mookei,
I am sending another follow up to check if you still have issues.
Michael L.
