Intel® ARC™ Graphics
3316 Discussions
Intel Arc Control adds fan control?
lunakid
Hi, is it possible to add fan control in Arc Control?
Sometimes the GPU load decreases and the fan also decreases in speed, but the temperature does not drop yet, so it is too late for cooling.
A770 cooling is not good, the temperature exceeds 80 degrees, it is easy to cause a black screen after.
If I lower the temperature limit from Intel Arc Control, it will trigger the black screen problem soon.
Jean_Intel
Hello lunakid,
Thank you for posting on the Intel️® communities. We understand you are recommending adding a fan control option in Arc Control.
We can confirm that we are working to implement the Fan Control option in Arc Control, and it should be enabled soon. Unfortunately, we are unable to commit to a deadline or update for a fix to be implemented in a new driver since this process requires further effort on our part.
Since this is still in progress, and to prevent duplication of efforts, we are considering closing this thread; however, we would like to know if you agree to close this thread.
Jean O.
lunakid
Hello Jean
Looking forward to future updates, I agree to close this thread.
DaVenzy12
You can download the app Control Center 3.0 in Microsoft store. There you can adjust your fan speed and other things.
Jean_Intel
Hello lunakid,
Thanks for your response.
Since you agree, we will now close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jean O.
