Intel® ARC™ Graphics
3357 Discussions
Intel HD 750
CleberGomes
Boa noite,
Não consigo obter uma resolução de tela acima de 1024 x 768.
Driver atualizado.
Monitor utilizado suporta até 1600 x 900 .
RandyT_Intel
Hi @CleberGomes,
Informamos que só posso apoiá-lo em inglês. Usei uma ferramenta de tradução da web para traduzir essa resposta, portanto, pode haver alguma tradução imprecisa
  • What is the make and model of your monitor?
  • How is the monitor connected to your system?(e.g., HDMI, VGA, DisplayPort, DVI, or via an adapter
  • Did this issue start after a specific event?(e.g., Windows update, driver update, hardware change)
  • Have you tried a different cable or port on your system?
  • Have you checked the available resolutions in both Windows Display Settings and your graphics control panel? (please provide screenshot)
  • Have you tried the monitor on another system
  • Are you using any adapters or docking stations between the PC and monitor?
  • What troubleshooting steps have you tried so far?
Randy T.
RandyT_Intel
Hi @CleberGomes,
Randy T.
RandyT_Intel
Hi @CleberGomes,
Since I haven't heard from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you may submit a new ticket if you need further assistance in the future.
Randy T.
