- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
....you're trying to achieve higher power levels for your LAPAC71H ARC A730m GPU. But to reach 120W, ensure you are using the GPU driver provided on the official website. This driver should support benchmark mode, allowing you to achieve the desired 85W or 120W performance.
JkeSmn
[Not an Intel Employee]
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I am using the official driver package provided to 71H
Intel_NUC_X15-LAPAC71-LAptop_kits-Driver_Pack-1.7
The Arc GPU driver version is 4575
I have tried the latest version of the driver, but it cannot use BAR normally and the maximum power of the benchmark mode is 75W
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Some GPUs allow users to adjust power settings through software provided by the Intel GPU manufacturer. Check if there are options to increase the power limit or performance mode within the GPU control panel. Cooling system can support the increased power demand of 120W. Insufficient power or cooling may prevent the GPU from running at higher power limits reliably firmware updates or BIOS updates for your system may include optimizations that allow for higher GPU power limits. Check for updates from your system manufacturer
Thank you.
JkeSmn
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Tyler...
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
