Intel® ARC™ Graphics
3295 Discussions
Monitor locked at 75hz and Not Showing 100Hz
Akrkhan71
Monitor locked at 75hz and Not Showing 100Hz on my samsung ls22d300gaw 21.5 100hz.please help me out my gpu is Intel Arc A580.
JeanetteC_Intel
Hello Akrkhan71,
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information here:
1) Is this a first-time setup and having an out-of-the-box issue?
2) Can you confirm that this is the exact monitor that you have (54.6 Cm Fhd Monitor With LPS Panel Ls22D300Gaw | Samsung India)?
3) How is the monitor connected to the Intel® Arc™ A580 Graphics (thru HDMI or DP)?
4) Are you using direct cable (e.g. HDMI to HDMI or DP to DP) or using a converter/adapter?
Additionally, I highly appreciate you sharing your system configuration so I can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save. *Attach the SSU log file as you reply.
JeanetteC.
ARMAN1996
ANSWER: YES
2) Can you confirm that this is the exact monitor that you have (54.6 Cm Fhd Monitor With LPS Panel Ls22D300Gaw /Samsung India )?
ANSWER: YES
ANSWER: HDMI
ANSWER: HDMI TO HDMI
ARMAN1996
Hello is there any update?
JeanetteC_Intel
Hello Akrkhan71,
Let us know if you have any questions.
JeanetteC.
ARMAN1996
ANSWER: YES
ANSWER: YES
2) Can you confirm that this is the exact monitor that you have (54.6 Cm Fhd Monitor With LPS Panel Ls22D300Gaw/Samsung India )?
ANSWER: YES
ANSWER: HDMI
ANSWER: HDMI
MUC
Honored Contributor I
Please check the driver settings for the color depth output. "BPC_8" is sufficient for this monitor. The panel can't display more than that anyway. The unavailability of 100 Hz may be due to the driver's calculation that 10-bit @ 100 Hz is not possible because of bandwidth limitations over HDMI 1.4 protocol which this monitor is limited to.
How Do I Set Color Depth or Color Format in the Intel Graphics Command Center?
If you are using Intel Graphics Software, you can find the setting here:
JeanetteC_Intel
Hello MUC,
Thank you for taking the time to share this information with your fellow community member. I sincerely appreciate your valuable input and contribution to the discussion.
Thanks for sharing this information with the community. Your input is greatly appreciated.
Sincerely,
JeanetteC.
JeanetteC_Intel
Hello Akrkhan71,
Did you get a chance to review the post from MUC?
Please let us know if you have any questions.
JeanetteC.
JeanetteC_Intel
Hello Akrkhan71,
Since I haven't received any response from you recently, I will go ahead and close this thread.
Sincerely,
JeanetteC.
