Intel® ARC™ Graphics
3395 Discussions
NT960QGK-KD72G(samsung galaxy book 4 pro) Crash
Catenoid
A crash occurs when running KollusPlayer on the Samsung Galaxy Book 4 Pro.
Below installation link
https://file.kollus.com/public/agent/KollusAgent-3.0.9.9.exe
Play execution is below
https://v.kr.kollus.com/YduzE3bn?pc_player_version=v3e&force_exclusive_player
Crash location is as follows.
C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_c183e9f567970786\igd9trinity32.dll
There seems to be an error with the Intel® ARC™ Graph's drive.
Other laptops play normally. (LG Electronics Ultra PC 15U50P-GR56K)
For reference, KollusPlayer uses IDirectDraw7/IDirectDrawSurface7.
Please confirm.
Hugo_Intel
Hello Catenoid
We will be closing this thread as we have not received a response from you. We hope that the issue was resolved after updating to the latest driver, also note there is even a newer driver version 31.0.101.5186. If you need further assistance, feel free to open a new topic.
Hugo O.
Hugo_Intel
Hello Catenoid
Thank you for posting on the Intel® ARC™ Graphics Communities.
Please share with us a report from the Intel® System Support Utility so we can get your driver details. Also, please let us know if Resizale Bar is enabled on your system
Hugo O.
Catenoid
Information received from Intel® System Support Utility
# SSU Scan Information
Scan Info:
Version:"3.0.0.2"
Date:"01-17-2024"
Time:"00:00:39.2136745"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"SAMSUNG ELECTRONICS CO., LTD."
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends International, LLC. P04RHA.380.231205.03 , 12-05-2023 12:00 오전"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Mobile"
Processor:"Intel(R) Core(TM) Ultra 5 125H , GenuineIntel"
Secure Boot State:"On"
SMBIOS Version:"3.6"
Sound Card:"Bluetooth® 오디오용 인텔® 스마트 사운드 기술"
Sound Card:"Realtek High Definition Audio"
Sound Card:"디지털 마이크용 인텔® 스마트 사운드 기술"
System Manufacturer:"SAMSUNG ELECTRONICS CO., LTD."
System Model:"960XGK"
System SKU:"SCAI-PROT-A5A5-MTLH-PRHA"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "Intel(R) Arc(TM) Graphics"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1.00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Arc(TM) Graphics"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Arc+Graphics"
CoInstallers:"oem31.inf,iMTL_7D55_w10_DS,Internal,Intel(R) Arc(TM) Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmdn64.sys"
Driver Date:"11-18-2023 09:00 오전"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\iigd_dch.inf_amd64_c183e9f567970786\igdkmdn64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"31.0.101.5007"
INF:"oem31.inf"
INF Section:"iMTL_7D55_w10_DS"
Install Date:"Not Available"
Installed Drivers:"C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_c183e9f567970786\igd9trinity64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_c183e9f567970786\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_c183e9f567970786\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_c183e9f567970786\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_7D55&SUBSYS_C890144D&REV_08\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"120 Hz"
Refresh Rate - Maximum:"120 Hz"
Refresh Rate - Minimum:"24 Hz"
Resolution:"2880 X 1800"
Scan Mode:"Noninterlaced"
Service Name:"igfxn"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) Arc(TM) Graphics Family"
- "Mirage Driver"
Adapter Compatibility:"DemoForge"
Adapter DAC Type:"Not Available"
Adapter RAM:"Not Available"
Bits Per Pixel:"32"
Caption:"Mirage Driver"
CoInstallers:"oem88.inf,DFMirage,Not Available,Not Available"
Driver:"dfmirage.sys"
Driver Date:"01-11-2008 09:00 오전"
Driver Path:"C:\Windows\system32\drivers\dfmirage.sys"
Driver Provider:"DemoForge"
Driver Version:"2.0.105.0"
INF:"oem88.inf"
INF Section:"DFMirage"
Installed Drivers:"Not Available"
Manufacturer:"DemoForge"
Monochrome:"No"
PNP Device ID:"ROOT\DISPLAY\0000"
Service Name:"dfmirage"
Status:"Degraded"
Video Processor:"Not Available"
- "Memory"
Physical Memory (Available):"7.68 GB"
Physical Memory (Installed):"16 GB"
Physical Memory (Total):"15.59 GB"
- "BANK 0"
Capacity:"2 GB"
Channel:"Controller0-ChannelA"
Configured Clock Speed:"7467 MHz"
Configured Voltage:"500 millivolts"
Data Width:"16 bits"
Form Factor:"Unknown"
Interleave Position:"First position"
Manufacturer:"Samsung"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"K3KL8L80CM-MGCT"
Serial Number:"00000000"
Status:"Not Available"
Type:"Synchronous"
- "BANK 0"
Capacity:"2 GB"
Channel:"Controller1-ChannelA"
Interleave Position:"Second position"
Type:"Synchronous"
- "BANK 1"
Capacity:"2 GB"
Channel:"Controller0-ChannelB"
Type:"Synchronous"
- "BANK 1"
Capacity:"2 GB"
Channel:"Controller1-ChannelB"
Type:"Synchronous"
- "BANK 2"
Capacity:"2 GB"
Channel:"Controller0-ChannelC"
Type:"Synchronous"
- "BANK 2"
Capacity:"2 GB"
Channel:"Controller1-ChannelC"
Type:"Synchronous"
- "BANK 3"
Capacity:"2 GB"
Channel:"Controller0-ChannelD"
Type:"Synchronous"
- "BANK 3"
Capacity:"2 GB"
Channel:"Controller1-ChannelD"
Type:"Synchronous"
- "Motherboard"
BIOS:"P04RHA.380.231205.03, SECCSD - 1072009"
Caption:"마더보드"
Chipset:"Not Available"
Date:"12-05-2023 09:00 오전"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"NT960XGQ-A51AG"
Serial Number:"1_______"
Status:"OK"
Version:"_________"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Bluetooth Device (Personal Area Network)"
Caption:"Bluetooth Device (Personal Area Network)"
CoInstallers:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"bthpan.sys"
Driver Date:"06-21-2006 12:00 오전"
Driver Path:"C:\Windows\system32\drivers\bthpan.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.22621.2506"
Index:"0011"
INF:"bthpan.inf"
INF Section:"BthPan.Install"
Installed:"Yes"
IP Address:"Not Available"
IP Subnet:"Not Available"
Last Reset:"01-17-2024 02:55 오후"
MAC Address:"_______"
Manufacturer:"Microsoft"
Net Connection ID:"Bluetooth 네트워크 연결"
NetCfgInstanceId:"{FE44F07E-0D1F-46DA-B5EA-5BDA83C49322}"
PNP Device ID:"BTH\MS_BTHPAN\6&EFF1A7D&0&2"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Power Management Supported:"No"
Product Type:"Bluetooth Device (Personal Area Network)"
Service Name:"BthPan"
Status:"Enabled"
Type:"이더넷 802.3"
- "Service Bindings"
Link-Layer Topology Discovery 매퍼 I/O 드라이버:
Link-Layer Topology Discovery 응답기:
Microsoft LLDP 프로토콜 드라이버:
Microsoft Networks용 클라이언트:
Microsoft 네트워크용 파일 및 프린터 공유:
인터넷 프로토콜 버전 4(TCP/IPv4):
인터넷 프로토콜 버전 6(TCP/IPv6):
- "Intel(R) Wi-Fi 6E AX211 160MHz"
Access Point:"88:36:6c:b3:fb:f4"
Authentication:
- "Caption":"Intel(R) Wi-Fi 6E AX211 160MHz"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Wi+Fi+6E+AX211+160MHz"
Channel:
Cipher:
Connection Mode:
Default IP Gateway:"192.168.0.1"
DHCP Enabled:"Yes"
DHCP Lease Expires:"01-17-2024 06:46 오후"
DHCP Lease Obtained:"01-17-2024 04:46 오후"
DHCP Server:"192.168.0.1"
Driver:"Netwtw14.sys"
Driver Date:"10-31-2023 12:00 오전"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\netwtw6e.inf_amd64_3600c12b90247a8b\Netwtw14.sys"
Driver Provider:"Intel"
Driver Version:"23.10.0.8"
Index:"0012"
INF:"oem26.inf"
INF Section:"Install_GEN_MAG_GfP2_211_AX_6G_2x2_WinT"
Installed:"Yes"
IP Address:"192.168.0.42;fe80::53de:d81b:701:c468"
IP Subnet:"255.255.255.0;64"
MAC Address:"____"
Net Connection ID:"Wi-Fi"
NetCfgInstanceId:"{E5A4582C-E430-404B-962B-87FFE7336A15}"
Network Name:"EC84B8EBACB4EC82AC20EAB095ED9599EC9AA920EC82ACEBACB4EC868C"
Network Type:
PNP Device ID:"PCI\VEN_8086&DEV_7E40&SUBSYS_00948086&REV_20\3&11583659&0&A3"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Intel(R) Wi-Fi 6E AX211 160MHz"
Profile:
Radio Type:
Receive Rate:
Service Name:"Netwtw14"
Signal Strength:
State:
Status:"Enabled"
Transmit Rate:
Type:"이더넷 802.3"
QoS 패킷 스케줄러:
- "Settings"
*DeviceSleepOnDisconnect:WoWLAN 연결 해제 시 절전 상태:"비활성화함 (0)"
*PacketCoalescing:패킷 통합:"활성화함 (1)"
*PMARPOffload:WoWLAN에 대한 ARP 오프로드:"활성화함 (1)"
*PMNSOffload:WoWLAN에 대한 NS 오프로드:"활성화함 (1)"
*PMWiFiRekeyOffload:WoWLAN에 대한 GTK 키 재입력:"활성화함 (1)"
*WakeOnMagicPacket:Wake on 매직 패킷:"활성화함 (1)"
*WakeOnPattern:Wake on 패턴 일치:"활성화함 (1)"
ChannelWidth24:2.4GHz 채널 폭:"자동 (1)"
ChannelWidth52:5GHz 채널 폭:"자동 (1)"
ChannelWidth6:6GHz 채널 폭:"자동 (1)"
CtsToItself:혼합 모드 보호:"RTS/CTS 활성화함 (0)"
FatChannelIntolerant:과부하 채널 비지원:"비활성화함 (0)"
IbssTxPower:전송 전원:"5. 최고 (100)"
IEEE11nMode:802.11n/ac/ax 무선 모드:"4. 802.11ax (3)"
Is6GhzBandSupported:초고대역 (6GHz):"활성화함 (1)"
MIMOPowerSaveMode:MIMO 절전 모드:"자동 SMPS (0)"
RoamAggressiveness:로밍의 주동성:"3. 보통 (2)"
RoamingPreferredBandType:기본 설정 밴드:"1. 기본 설정 없음 (0)"
ThroughputBoosterEnabled:처리량 부스터:"비활성화함 (0)"
uAPSDSupport:U-APSD 지원:"비활성화함 (0)"
WirelessMode:802.11a/b/g 무선 모드:"6. 듀얼 밴드 802.11a/b/g (34)"
- "Operating System"
.Net Framework Version:"4.0,4.8"
Boot Device:"\Device\HarddiskVolume1"
Internet Browser:"Internet Explorer,11.1, Microsoft Edge,120.0"
Locale:"대한민국"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 11 Home"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"2.88 GB"
Physical Memory (Available):"7.70 GB"
System Directory:"C:\Windows\system32"
Version:"10.0.22621 Build 22621"
Virtual Memory (Available):"9.14 GB"
Virtual Memory (Total):"18.46 GB"
Windows Directory:"C:\Windows"
- "Installed Updates"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB5012170:"Security Update [1/7/2024]"
KB5032393:"Update [1/7/2024]"
KB5033920:"Update [1/14/2024]"
KB5034123:"Security Update [1/14/2024]"
- "Processor"
- "Intel(R) Core(TM) Ultra 5 125H"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 170 Stepping 4"
- "Chipset Name":"Intel(R) Core(TM) Ultra 5 125H"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Core+Ultra+5+125H"
CPU Speed:"1.20 GHz"
Current Voltage:"7. volts"
Driver:"Not Available"
Driver Date:"04-21-2009 12:00 오전"
Driver Path:"C:\Windows\system32\drivers\intelppm.sys"
Ext. Family:"Not Available"
Family:"Other"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"14 x 192 KB"
Level 2 Cache:"14 x 14336 KB"
Level 3 Cache:"18 MB"
Load:"Not Available%"
Manufacturer:"GenuineIntel"
Model:"170"
Name:"Intel(R) Core(TM) Ultra 5 125H"
Number of Cores:"14"
Number of Cores Enabled:"14"
Number of Logical Processors:"18"
Part Number:"Not Specified"
Processor ID:"BFEBFBFF000A06A4"
Revision:"Not Available"
Serial Number:"None"
Service Name:"intelppm"
Status:"OK"
Stepping:"4"
- "Storage"
- "SAMSUNG MZVL2256HCHQ-00B"
Capablities:"Random Access, Supports Writing"
Caption:"SAMSUNG MZVL2256HCHQ-00B"
Cylinder - Total:"31130"
Description:"디스크 드라이브"
Error Code:"Device is working properly"
Firmware Revision:"GXA7GK2Q"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Interface Type:"SCSI"
Manufacturer:"(표준 디스크 드라이브)"
Model:"SAMSUNG MZVL2256HCHQ-00B"
Partitions:"3"
Physical Sector Size:"4096"
PNP Device ID:"SCSI\DISK&VEN_NVME&PROD_SAMSUNG_MZVL2256\5&308F4E2A&0&000000"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
SCSI Bus:"0"
SCSI LUN:"0"
SCSI Port:"0"
Sectors - Per Track:"63"
Sectors - Total:"500103450"
Serial Number:"______"
Size – Available:"193.68 GB"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"7938150"
- "C:"
Availability:"Not Available"
Caption:"C:"
Compression Method:"Not Compressed"
Description:"로컬 고정 디스크"
File System:"NTFS"
Name:"Not Available"
Serial Number:"0455705E"
Size – Available:"193.69 GB"
Volume Dirty:"No"
Heads - Total:"255"
Index:"1"
INF:"disk.inf"
Partitions:"1"
PNP Device ID:"SCSI\DISK&VEN_NVME&PROD_SAMSUNG_MZVL2256\5&285184D9&0&000000"
SCSI Bus:"0"
SCSI LUN:"0"
SCSI Port:"1"
Size – Available:"238.37 GB"
Status:"OK"
- "D:"
Caption:"D:"
File System:"NTFS"
Serial Number:"32F210A6"
Volume Dirty:"No"
...#SSU#...
Catenoid
This is information obtained using a utility provided on another computer.
Although it is not the same model, the same error occurs.
Hugo_Intel
Hello Catenoid
The information from the report you shared is incomplete, please follow the instructions from the article we shared in our previous post to save the full Intel® System Support Utility report as a .txt file and attach it to your next post.
Hugo O.
Catenoid
Send two files from another user. Please check
Hugo_Intel
Hello Catenoid
Thank you for the information. I see there is an outdated version of the driver installed. Please uninstall the current version using Display Driver Uninstaller, once uninstalled, update to the latest version 31.0.101.5085.
Hugo O.
Hugo_Intel
Hello Catenoid
Please let us know if you were able to update your system to the latest graphics driver we recommended in our previous post and let us know whether the Kollus player is still crashing on your system.
Hugo O.
Hugo_Intel
Hello Catenoid
Hugo O.
