Intel® ARC™ Graphics
3297 Discusiones
New driver arifacts Arc A380.
Mynameforum
Nuevo Colaborador I
1.865 Vistas
This started to appear on the screen when i updated to gfx_win_101.6874.
Its not that annoying but it did not happen before.
Now im updated to latest driver gfx_win_101.6881, the issue is still there.
32.0.101.6793 has no issues as i remember.
For debug: this happens when game window is not focused.
0 kudos
15 Respuestas
Mike_Intel
Moderador
1.800 Vistas
Hello Mynameforum,
  1. Are you using an Intel brand Arc A380?
  2. How did you update the driver?
  3. Are you getting the issue inside a game or even in desktop?
  4. What are the troubleshooting steps that you tried so far?
Michael L.
Mynameforum
Nuevo Colaborador I
1.769 Vistas
1. Sparkle Arc A380 Elf.
2. DDU then clean install new version.
3. I dont get issue in the game/games or destktop separately, but when i run game in borderless window and then swich to windows explorer on top of the game it can appear randomly, its very rare and i cant repeat it constantly for debug its random.
4. Tried stock without any kind overclocking - the same.
Mynameforum
Nuevo Colaborador I
1.748 Vistas
Here a thing, i started to get this issue when i enabled smooth sync in the driver. This can be coincidence, but now im disabled smooth sync and issue gone for now, need more time to test.
Mynameforum
Nuevo Colaborador I
1.656 Vistas
Ok, i tested one day. Smooth sync is causing that screen artifacts now im sure.
Game in borderless window and anything on top of it can cause artifacts randomly when smooth sync on.
My screen is 100 hz connected through HDMI.
Please made a fix, smooth sync is a nice feature actually.
Mynameforum
Nuevo Colaborador I
1.693 Vistas
Ok i tested it one day, smooth sync is causing that artifacts now im sure.
Game in borderless window and anything on top of it can randomly cause artifacts.
Please made a fix, smooth sync is actually nice feature.
Mike_Intel
Moderador
1.651 Vistas
Hello Mynameforum,
Thank you for the update.
Let me gather additional information regarding this issue.
  1. Also please share the screenshot of the settings that you mentioned.
  2. Please help generate the SSU logs of your system. Kindly refer to the link below on how to generate the logs:
Michael L.
Mynameforum
Nuevo Colaborador I
1.615 Vistas
Did everyting. Also the name of the game where i saw this artifacts - Uncharted 4.
Mike_Intel
Moderador
1.578 Vistas
Hello Mynameforum,
I have seen the video that you sent. Let me check, have you tried to re-seat your Arc A380 and also tried different cables for the display?
Michael L.
Mynameforum
Nuevo Colaborador I
1.533 Vistas
Re-seat - no. Cable is from LG that comes with monitor it should not be that cheap/bad.
The card worked/works fine for 4 month there was not any screen artifacts aside artifacts/glitches in games and then i tried to on the new feature smooth sync to see what it is and thouse artifacts appeared.
I tested another game in borderless - ratchat and clank rift apart.
It do not had stip shaped artifacts like uncharted 4, but very-very rare flickering rectangle instead.
In the game vsync should be off, in the driver smooth sync should be on.
Both games from Sony owned studios, they share some code and partially game engine from game to game.
Also i tested other games there no problems.
Mike_Intel
Moderador
1.493 Vistas
Hello Mynameforum,
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Mike_Intel
Moderador
1.416 Vistas
Hello Mynameforum,
Let me also ask the following details for me to document and it may help me simulate this issue.
  1. Can you tell me which digital service/platform did you use to play the game?
  2. Please provide some screenshot of the game settings to accurately replicate the issue.
Michael L.
Mynameforum
Nuevo Colaborador I
1.362 Vistas
1. Steam UNCHARTED™: Legacy of Thieves Collection
2. I deleted game and move on, but its medium setting or something, A380 not super powerful. The key is the sync setting.
Game should run borderless and in the game vsync should be off at the same time in the intel graphics software
smooth sync should be on and also its needed to place on top of the running game other windows like browser + windows explorer or other apps
You can move windows or hover the mouse pointer over windows, for example over 'my computer' window, there some little animation inside, you can trigger animation hovering with mouse pointer. The game still runs on the background.
At this state i got that issue. If i disable smooth sync in the driver issue just dont appear. Restart of the compurer is required.
All this on windows 10 and screen refresh rate 100.
Now im playing Sunset Overdrive in borderless with smooth sync on. Zero issues.
Mike_Intel
Moderador
1.306 Vistas
Hello Mynameforum,
Thank you for the quick reply
Let me further check this issue and post the response on this thread once it is available.
Michael L.
Mike_Intel
Moderador
1.263 Vistas
Hello Mynameforum,
Let me thank you for sharing your experience and insights regarding the settings and performance with the Intel Arc A380. I really want to investigate the issue further if you decide to reinstall the game and provide additional information for replication. For now, I will be closing this inquiry. However, if you have any other concerns or issues with the graphics card, you are always welcome to create a new thread, and we will be happy to assist you.
Michael L.
Mynameforum
Nuevo Colaborador I
1.190 Vistas
I will look for simplier game project and straight instruction how to replicate it. I saw this in two Sony games.
Maybe there little chance it was electric noise/interference in wires or something.
Cant reinstall the game because internet provider (slowers down transfer speed after 300 gb wich is out till next month).
Responder
