Intel® ARC™ Graphics
3332 Discussions
No Picture
Crille
i have
Asus prime b760 plusD4
intel i5 12400
16gb ddr4
ssd 500gb
old GPU
Radeon vega rx
new
Intel ARC B580
the computer is booting but the display is dead
i have tryed hdmi and DP
RandyT_Intel
Hi @Crille,
  • Have you tried using different HDMI or DisplayPort cables to rule out cable issues?
  • Is the monitor powered on and set to the correct input source?
  • Have you updated the BIOS on your Asus Prime B760 Plus D4 motherboard to the latest version?
  • Have you tested the monitor with another computer or device to ensure it is functioning correctly?
  • Have you tried connecting the old Radeon Vega RX GPU to see if the display works with it?
  • Have you tested the Intel ARC B580 GPU in another system to verify its functionality?
  • Have you tried using a different PCIe slot on the motherboard?
  • What operating system are you using on your computer?
Please note:
For Operating System
  • Windows® 10 64-bit 22H2 or newer
  • Windows 11* 64-bit
  • Confirm the Operating System is using the GPT partition type:
      • For Windows 11, this mode is configured by default.
      • For Windows 10, the partition type can be converted if installed with an MBR partition type.
    • Refer to the Microsoft Tool & Guide for more information.
Compatibility Support Module (CSM) or Legacy Mode must be disabled, and UEFI boot mode must be Enabled.
Check this article: Intel® Arc™ Graphics – Desktop Quick Start Guide
Warm regards,
Randy T.
RandyT_Intel
Hi @Crille,
Randy T.
RandyT_Intel
Hi @Crille,
Since I haven't heard from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you may submit a new ticket if you need further assistance in the future.
Randy T.
