Intel® ARC™ Graphics
3304 Discussions
Old DX9 game crashing
modx
The game crashes soon after I log in.
Event viewer logs:
Faulting application name: DFO.exe, version: 2.24.5.26, time stamp: 0x63e21bf0
Faulting module name: ntdll.dll, version: 10.0.22621.900, time stamp: 0xa97a9ed6
Exception code: 0xc0000005
Fault offset: 0x000000000006b514
Faulting process id: 0x0x173C
Faulting application start time: 0x0x1D94544C8AF8464
Faulting application path: C:\Neople\DFO\DFO.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: b6c3c28d-f40b-4e1f-9e67-555d75799637
Faulting package full name:
Faulting package-relative application ID:
I'm using the latest driver and game version. No distro service.
modx
my ssu file
Jean_Intel
Hello modx,
Regarding your issue about the DFO game, we would like to ask for a description of the step-by-step you follow to face the problem. This would help us investigate the issue. It would be ideal, if you can, to record a video showing the steps and the problem behavior.
Also, we want to confirm what you mean by stating: "No distro service.". Is this related to the game distribution service? If so, what program did you use to install the game?
Jean O.
modx
Very easy to reproduce:
  1. Open game launcher
  2. Launch the game
  3. login
  4. sit at the home screen and then the game closes.
I've attached a video from when I login tot he game to when the game crashes. The game just closes itself when it crashes.
Yes. I meant it game is not from a distribution service. I downloaded the game installer from their website
Jean_Intel
Hello modx,
Thank you for the update.
Regarding your issue, we would like to recommend you try completely uninstalling the game and re-installing the game. It is important to mention that clean installing software can help to fix specific issues that can be associated so any additional software that might be causing malfunction.
Jean O.
modx
I tried re-installing the game. Game still crashes but the error is gone.
Jean_Intel
Hello modx
We will look further into this scenario and respond at our earliest convenience.
Jean O.
Jean_Intel
Hello modx,
Thanks for your patience.
This time, we would recommend you perform a clean installation, installing the latest driver version available on our download center, driver 31.0.101.4146. It is important to mention that sometimes corrupted files from previous installations of drivers can linger on a system which can cause driver updates to not work as expected
Jean O.
modx
Jean_Intel
Hello modx,
We are glad to hear that the issue is now solved and everything is working fine.
Jean O.
