Intel® ARC™ Graphics
3285 Discussions
Opção Desligar led na arc b580 Intel Graphics Limited Edition
Alan1330
Como desligar o led da logo Intel Graphics B580 Limited Edition???
o brilho é forte e uso no quarto e incomoda a noite por perturbar outras pessoas e me distrair
Earl_Intel
Hi Alan1330,
Informamos que só posso apoiá-lo em inglês ou, se preferir, posso transferi-lo para uma equipe diferente que ofereça suporte ao seu idioma. Usei uma ferramenta de tradução da web para traduzir essa resposta, portanto, pode haver alguma tradução imprecisa.
I am aware of how uncomfortable bright lights can be, particularly for those who are light-sensitive.
I'll try my best to assist you in dimming or turning off your B580's Intel Arc light.
  • Is the logo also lit up even if the system is off?
  • Have you already tried checking on the BIOS if there are settings on how to disable the RGB lights?
Earl E.
Alan1330
If the soft intel cannot customize the LEDs, it's a failure with the players; having color modes, intensity on or off is basic.As for BIOS or other means, there’s no way to disable it, but a piece of black electrical tape over the LED has solved it in an improvised way.
Earl_Intel
Hello Alan1330,
Thank you for sharing this valuable information with us.
I understand your concerns about the LED light from the Intel Arc logo being too dazzling.
Rest assured, I will check internally and explore possible solutions for this issue.
I will provide you with an update on this thread as soon as possible.
Earl E.
Earl_Intel
Hi Alan1330,
Thank you for your patience.
We've encountered a similar situation related to your issue, which you can find here: Solved: How to turn off intel arc logo on B580 - Intel Community
After further investigation, there is currently no method, option, or application available to disable the LED logo on Intel Arc B580 GPUs.
We understand how important this feature is, especially due to the brightness of the light. Rest assured, we acknowledge your concern. However, at this time, there is no resolution or estimated timeline for this request.
We sincerely apologize for any inconvenience this may have caused. Your feedback is highly valued, and I will ensure it is shared with the team for future consideration.
Earl E.
