Intel® ARC™ Graphics
3455 Discussions
Performance Intel Arc A770
addelucas123
New Contributor II
Goodnight
I am David and I have come to say that it will improve the performance of the Intel Arc A770 graphics card through the drivers to compete with RTX 3060 TI, you must exceed at least 10%, that is, Arc A770 exceed 10% of the RTX 3060 Ti and catch up with the RTX 3070.
Sorry to bother you, I'm just saying this because I'm watching a performance video.
Cheers
addelucas123
New Contributor II
good morning
I'm David, I come to say that I tried several alternatives to update one in the end 31.0.101.3959 Y 31.0.101.3975 I left the 3959 and nothing and the configuration is currently in high quality DirectX 12 full screen 144Hz is when pongp full screen and 144Hz throws me 1 FPS vertical synchronization Yes, It is when I activate full screen and 144Hz in high quality in DirectX 12 is when I get FPS 1 FPS
addelucas123
New Contributor II
good morning Luis
I am going to send you two videos Vulkan and DirectX 12 default configuration in red dead redemption 2, so when you see the video directly ported urgently let the developer engineers of intel or intel drivers see it and get drivers out as soon as possible to see if you can take out quickly.
For which there are two videos and the PC system, that is, the characteristics, controllers, etc., has everything, so I only have that, I just send it to you and report it, I want it
And I'm sorry for being like that, it's my way of being, I know it's not my fault, but I don't like being deceived or anything, that's why I joined you because you are the best, but I want to solve it through drivers and correct the problem and performance both DirectX 12 and vulkan.
DirectX 12: https://www.youtube.com/watch?v=34_-MZkpiVQ&ab_channel=DavidDeLucasRuiz
Vulkan: https://www.youtube.com/watch?v=QgLY1cL9zyM&ab_channel=DavidDeLucasRuiz
Best regards.
David
addelucas123
New Contributor II
Here is a performance test DirectX 12 and Vulkan red dead redemption 2
LuisGustav_A_Intel
Hello David1997,
Let me investigate this further so I can submit updates.
Luis A.
addelucas123
New Contributor II
Ok but send updates I have the latest version and I already did all the steps and nothing, the only thing is to put drivers to correct the problem and performance DirectX 12 Red Dead Redemption 2
Saabjock
ARC is going in the right direction performance wise.
Here is a clip from my test today with Assetto Corsa Competizione (no audio).
This sim is an outright frame killer for most GPUs, so to see it run on A770 is a feat onto itself.
I was getting between 28-31 fps most of the time and that was with many epic settings and a beta driver.
As long as Intel keeps pressing forward, this can only get better.
https://www.youtube.com/watch?v=ORwrwes2FS0&t=52s
Saabjock
https://www.youtube.com/watch?v=byccCzoAyLQ
More performance from ARC.
This time it is Automobilista2 in BMW at SPA.
LuisGustav_A_Intel
Hello David1997, thank you for waiting. For testing purposes we wonder the following.
Do you get the same issues with lower resolutions/refresh rates?
Luis A.
addelucas123
New Contributor II
If the Intel Arc drivers when you install it says 144Hz but in the game it says 50Hz and it is in the drivers putting DirectX 12, that is to say if I put 144Hz in Red Dead Redemption 2 but activating vertical synchronization with the full screen there is 1 FPS and it is The drivers that are impermenting that game and the game blocks throw 1 FPS etc. It is the drivers that we are going to report.
When I put Vulkan there if it goes well but in DirectX 12 it goes wrong and it is the Intel Arc drivers that are blocking and experiencing performance in the game Red Dead Redemption 2 PC
LuisGustav_A_Intel
Hello David1997,
Thank you for the information and patience. As I am carrying out an investigation, I may need the below.
May I get screenshot of the configuration in game and ARC driver as you state it shows 50 hz and 144 hz correspondingly?
Do you present the same problem using the combination of a lower resolutions/refresh rates?
Luis A.
addelucas123
New Contributor II
Here is 50Hz in the game red dead redemption 2 PC when I activate 144Hz with full screen is when it throws me at 1 FPS
addelucas123
New Contributor II
but if the video that I sent you shows 144Hz 1 FPS, look at it and please report the drivers that I am having a problem with the performance of red dead redemption 2 PC activating DirectX 12 1 FPS when activating DirectX 12 144Hz with full screen I get Shoot 1 FPS, look at the video please and please report it because at the beginning of January or at the end of January or in the middle of January I want a solution, that is, drivers to correct the problem, etc.
DirectX 12 https://www.youtube.com/watch?v=34_-MZkpiVQ&ab_channel=DavidDeLucasRuiz
Vulkan https://www.youtube.com/watch?v=QgLY1cL9zyM&ab_channel=DavidDeLucasRuiz
addelucas123
New Contributor II
good evening
I'm David, I'm sending you the latest version of drivers for Intel Arc A770 16GB 31.0.101.4032 the image is in Spanish and I'm trying to translate with my word but we're still the same with the performance issue DirectX 12 Red Dead Redemption 2 1 FPS for which I already removed drivers I want from now on to correct the problem you are experiencing thanks and regards
LuisGustav_A_Intel
Hello David1997,
Thank you for the update on the new driver, and results. I check into this for pursuing a solution.
Luis A.
addelucas123
New Contributor II
Do not look for a solution because the problem is in the drivers because when I run DirectX 12 Red Dead Redemption 2 it already lets me put 144Hz but if I put vertical synchronization it is deicr putting Yes there is where it lowers me to 1 FPS and when I deactivate vertical synchronization it is when it puts 50Hz on me, I tried several games and it goes well except Red Dead Redemption 2 PC so I did not look for a solution because to solve it is drivers and drivers
addelucas123
New Contributor II
What's more, if I want to play Red Dead Redemption 2 DirectX 12 from 50 to 60 FPS I have to deactivate vertical synchronization and 50Hz because since I put 144Hz and vertical synchronization in It doesn't throw me 50 to 60 FPS now if I put in vertical synchronization in Yes 1 FPS and that smells like it's drivers because Rockstar says it's not a video game problem, it's a driver problem in optimization, it's preventing it from working because if the rest of the games go well, then there is a problem with the specific drivers or something similar that It is impeding the performance I wanted by removing drivers and drivers
LuisGustav_A_Intel
 Hello David1997,
Thank you for your patience, and the whole information provided
before.
Upon conducting the investigation, we determined the problems replicated at our end as well, the game issues are assigned to the driver team now. This team will work on it.
  • Red Dead Redemption 2 bug ID: 18020723290
  • Cyberpunk 2077 bug ID: 14018065802
Luis A.
addelucas123
New Contributor II
Good!!!
From now on, correct the problem, performance also that the Intel Arc A770 16GB graphics card exceeds RTX 3060 ti, please step on the RTX 3070, indeed to improve good bad let's work hard.
On the other hand, I would like you to communicate to Intel Superior about the issue of call unblocking because I am Spain and I have to call Intel Support but of course the political issue, Intel from Spain told me that I should contact the United States of Intel or something like that so that I unlocked with my number +34640521307, tell it to superior and have them talk to Intel Spain so that they can unlock me and I promise I'll behave well.
Thanks a lot
LuisGustav_A_Intel
Hello David1997,
Thank you for the feedback.
Please provide the link review you watched for a point of comparison against RTX 3060 TI for analisys.
You should not have any call blocking, probably contact your mobile provider for checking that aspect international calling allowance.
You can find multiple ways of communicating with support, visit the website and find your most convenient.
https://www.intel.com/content/www/us/en/support/contact-intel.html?productId=873#@2
Luis A.
addelucas123
New Contributor II
But if Intel told me that it had me blocked that to request an unlock I should contact you, I don't know. On the other hand, the driver report that is reflected on the subject of red dead redemption 2 and cyberpunk 2077 is worth it please. Thank you
addelucas123
New Contributor II
I tell you that I want the Intel Arc A770 16GB graphics card to surpass the RTX 3060 Ti, I am sending you the comparison of the Intel Arc A770 16GB vs RTX 3060 Ti, the test I did, but in any case, it surpasses it even more, that is, the ARC A770 16GB that surpasses you even more.
What does test mean, Well, the performance that I want is to say, rather, what we want is for the Intel Arc A770 16GB graphics to outperform the RTX 3070 by at least 5% and the RTX 3060 Ti by 15%, I did a test with my card Intel Arc A770 16GB graphics together with an i7-11700K is almost almost NIVIDA's RTX 3070 to see if you can beat it. On the other hand, the drivers as I told you about the subject of red dead redemption 2 and cyberpunk 2077 please, thanks
https://www.3dmark.com/spy/34405914
https://www.3dmark.com/spy/34390481
https://www.3dmark.com/spy/34381208
