Intel® ARC™ Graphics
3382 Discussions
Problem Capture Intel Arc Error 17
addelucas123
New Contributor II
buenas noches
Tengo un problema cuando quiero capturar Intel Arc. Los pasos que siguieron fueron los siguientes:
1. Ingrese a la configuración del modo seguro
2. Desinstale la versión anterior del controlador Intel Arc A770 Display Driver Uninstaller (DDU)
3. Instale la última versión de los controladores Intel Arc A770 31.0.101.5333
Lo he intentado de varias maneras y no puedo capturarlo con la tarjeta gráfica Intel Arc, y me pasó desde que compré el producto de la tarjeta Intel Arc A770 LE.
ACarmona_Intel
Hello Addelucas123,
We will do further research on this matter and post the response on this thread once it is available.
Have a fantastic day, and thank you very much for your patience and understanding!
Carmona A.
VonM_Intel
Hi, addelucas123.
Thank you for patiently waiting.
As I looked into the issue (Error Code 17, while capturing from the Intel Arc) it might be caused by a variety of factors. As such, I would like to share this link/article: Encountered Error Code 17 When Capturing Video from Intel® Arc™ Control Panel, which might help fix the issue with Error Code 17.
Also, have you tried testing an alternative graphics driver version, such as the previous ones (e.g., 31.0.101.5330)? This allows us to identify whether the problem remained even in prior versions of the graphics driver.
Von M.
addelucas123
New Contributor II
good night
I'm David, I have everything updated with the steps that you mentioned or that you are going to mention to me, and the problem persists, that is, if I activate the built-in monitor speakers it works, and if I deactivate it it works, but if I put the speakers on it doesn't work I'll send you a video of the steps I did, etc., so you can see that I do it well, Everything is updated to the latest version and there is no way, I wanted to report it and please, I have another new thread I would like you to read it
https://www.youtube.com/watch?v=ldOIVOcOMqg&ab_channel=DavidDeLucasRuiz
https://www.youtube.com/watch?v=4bTS7_buK3Y&ab_channel=DavidDeLucasRuiz
addelucas123
New Contributor II
Good night
I have tried several alternatives, I have tried version 31.0.101.5330 and also the most recent version which is 31.0.101.5333, but the problem continues and persists. I did a clean uninstall with Display Driver Uninstaller DDU, and I reinstalled with several different versions. but it still persists, I sent you an explained video, this must be reported, please there is another new thread open without answering, could I answer, thank you
VonM_Intel
Hi, David.
I appreciate you for updating the graphics driver. We will do further research on this matter and post the response on this thread once available. Also, you may paste the link to your other thread here so we can investigate further.
Von M.
VonM_Intel
Hi, addelucas123.
There is a known issue with Realtek’s Sonic Studio III and Intel Arc Control that may result in the error message. This is under investigation hence for now the only recommendation we can provide is to uninstall this application, kindly refer to: https://www.intel.com/content/www/us/en/support/articles/000095476/graphics.html
However, we noticed that you have already opened a new case number about this same issue, please know, however, that we will now be closing this case. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Von M.
addelucas123
New Contributor II
good morning
I have the latest version Realtek Sonic Studio III v6.3.9600.2342, I uninstalled the Realtek Sonic Studio III drivers and reinstalled from the beginning with a clean installation, and even so the problem continues and persists, I have already done several tests even installing Windows 10 from scratch , And it continues and it is no longer a computer problem, It is now a driver problem, so please take it very seriously
Greetings
DAVID
addelucas123
New Contributor II
I reinstalled the latest version v6.3.9600.2342, and nothing persists, so you have to report it as soon as possible
addelucas123
New Contributor II
Good afternoon
I continue and the problem with Capture persists. If I choose Realtek Speakers, I get the following: Cannot start capture, Device malfunction. Make sure you are not connected to a VPN. Error code 17, Verify that it is not connected and it is indeed disconnected, but the problem persists with the latest drivers 31.0.101.5382 Intel Arc A770, I have already done a clean uninstallation, I am not going to repeat the same song again, this must be reported, thank you
greetings
David
Orbsoflight
Hi
I have an Intel NUC`3 Extreme kit with the ARC770 card.  I used to be able to stream via the Arc Control center or via OBS but now I get the same error as mentioned in this thread.....  only when doing streaming  (recording / capture works ok)
The error is Device:  Operational failure, please check you are not connected to a VPN  ERROR CODE 17
I have upgraded to the layesy graphics driver but that didnt work
Orbsoflight
Dear Intel Support,
Is there any progress in finding a solution for this issue?  I used to be able to use the BROADCAST function of the ARC Control Center but now when I try to broadcast I get the error code 17.  The message talks about making sure that there is no VPN which seems a strange error, but I am not connected to a VPN
Attached is the SSU output
