Intel® ARC™ Graphics
3300 Discussões
QSV HW encoding not working in OBS with driver version 32.0.101.6557 and above
nanashi
Novato
10.641 Visualizações
QSV hardware encoding does not show up as a list of encoders on OBS and cannot be used with driver version 32.0.101.6557 and above. As a workaround, I am now using version 32.0.101.6460, but I am no longer able to increase the driver version.
# HW/SW info
- GPU
  - Intel Arc A750
- OS
  - Windows 11 24H2 (OS Build 26100.3194)
- Graghics Driver
  - 32.0.101.6557, 32.0.101.6559(WHQL)
- Application
  - OBS Studio 31.0.1 (64 bit) (2025/1/18 release, current latest)
# How to Reproduce
- install intel GPU driver version 32.0.101.6557 and above
- run OBS and with menu bar open 'file' > 'settings' > 'output' and check 'video encoder' list
  - Quicksync AV1/H.264/HEVC do not appear in the list
  - In OBS log file recorded 'Seems the QSV test subprocess crashed. Better there than here I guess. Let's just skip loading QSV then I suppose.'
# Additional Info
Similarly, ffmpeg is giving the error 'Failed to init HECI driver' with GPU driver version 32.0.101.6557 and above. It was also reported below.
https://community.intel.com/t5/Graphics/Failed-to-init-HECI-driver/td-p/1662203
I am assuming that this is a problem with the intel GPU driver and not OBS.
1 Solução
Felipe_Intel
Moderador
9.958 Visualizações
Hello all, this issue is not seen in our latest driver 32.0.101.6632. Please download (link below), install and test with this driver. I'd really appreciate your feedback on this. https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Ver solução na publicação original
12 Respostas
JedG_Intel
Moderador
10.519 Visualizações
Hello nanashi,
I understand that you're having issues with the newer drivers as QSV encoding is not showing as an option on OBS. Have you tried using other recording software to further isolate the issue? I'm asking this so we can narrow down the investigation that we'll be conducting. Please also send a screenshot of the options available on your end.
I hope to hear from you soon.
Jed G.
nanashi
Novato
10.488 Visualizações
Attached are logs of QSV hardware encoding in ffmpeg command line, as I wrote in the 'Additional Info' section of my first post.
The following commands are used to output in QSV AV1 format with hardware encoding (approximately around line 65 of each log file).
> ffmpeg -hwaccel_output_format qsv -f lavfi -i mandelbrot=size=1920x1080 -t 5 -c:v av1_qsv output.mp4
When executed with driver versions 32.0.101.6460 and 32.0.101.6559, respectively, the output file itself is done successfully in both cases, but the latter produces the following error.
> IGSC: (D:\qb\workspace\31779\source\igsc-master\lib\igsc_lib.c:gsc_driver_init():218) Error in HECI init (3)
> IGSC: (D:\qb\workspace\31779\source\igsc-master\lib\igsc_lib.c:igsc_device_subsystem_ids():1597) Failed to init HECI driver
I have not compared them with any software other than OBS and ffmpeg.
JedG_Intel
Moderador
10.281 Visualizações
Hi nanashi,
Thank you for sharing all this information. I will be investigating this matter and I will get back to you as soon as possible.
Jed G.
Jachia
Principiante
10.202 Visualizações
I also have same problem
JedG_Intel
Moderador
10.164 Visualizações
Hi nanashi,
I am reaching out to provide you with a series of steps to assist with the ongoing investigation.
  • Try to install the latest driver 101.6559
  • Launch OBS with Admin rights
Once done, kindly inform me if the HECI error persists and if you are still unable to select the encoders.
Jed G.
nanashi
Novato
10.138 Visualizações
I installed driver version 32.0.101.6559, restarted OS to confirm (did not change OBS or ffmpeg versions).
I started each of OBS and ffmpeg with administrator privileges and both had no problems. I am attaching the logs as before, just in case.
However, there is some risk in continuing to run them with administrator privileges in the future, so I have reverted the drivers back to 32.0.101.6460 again.
In another thread, I saw that a driver update is planned to address this issue. So I am also planning to wait for a driver fix.
https://community.intel.com/t5/Intel-ARC-Graphics/Intel-Driver-Causing-Issue/m-p/1669199#M21274
JedG_Intel
Moderador
10.099 Visualizações
Hello nanashi,
I really appreciate this information, it is really helpful. I'll be continuing the investigation and I'll give you an update again as soon as possible.
Jed G.
bo1983
Novato
10.035 Visualizações
same problem with handbreal or vlc
Felipe_Intel
Moderador
9.959 Visualizações
bo1983
Novato
9.935 Visualizações
nanashi
Novato
9.901 Visualizações
The problem is gone with driver version 32.0.101.6632 for both OBS and ffmpeg. Thank you very much for your help.
JedG_Intel
Moderador
8.960 Visualizações
Hi @nanashi @bo1983,
After further testing, we can confirm that the issue is fixed and I agree with @Felipe's response. Since you were able to confirm that the problem is resolved, I will now proceed with closing this inquiry. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Jed G.
Responder
