Intel® ARC™ Graphics
3305 Discussions
Question/Suggestion: Changing interface language for Arc Control Panel / OSD
LynxRufus
it seems Intel Arc Control panel is automatically switching to/choosing language,
based on whatever your windows system locale / display language is set to / using system default..
Is there a hidden way to force the entire App including the Settings Menu & telemetry OSD  launching with a different language?
My windows system (win 10 pro 22H2) is set to german, it's something I do not want to change,
but I prefer certain apps in english(us) ...
mostly OSD / telemetry apps like HWiNFO, GPU-Z, CrystalDiskInfo etc, and also many if not all games.
I see those different language files are already in the Arc Control install folder,
can I force it to use english eg.?
Why is there no easy switch inside the app?
Thx in advance.
Jean_Intel
Hello LynxRufus,
Thanks for your feedback for the Arc Control application. We have shared the information given. We will pass the information on to the corresponding team in charge. Let us know if you have any questions.
Jean O.
LynxRufus
well, I'm not sure because  I guess it has been brought up a lot , but if it hasn't :
in addition,
it would be nice, if we could re-size the entire arc control panel & the telemetry overlay to our personal needs,
or set a custom high-dpi scaling factor.
In my case, I have a rather small 4K screen, so I set windows desktop high-dpi scaling to 150% .
But the entire Arc Control Panel & the overlay looks way too big,
pretty bloated, almost across the entire screen space then.
Especially if you could resize the performance telemetry overlay manually, that would be great.
it can get in the way ingame quite often..
Jean_Intel
Hello LynxRufus,
Thanks for your response.
We appreciate your feedback. We noticed that the recommendations you shared on your latest posts are similar to the ones you shared on another personal thread. It is important to mention that we have already shared this information with the appropriate team in charge. We are continuing to improve our products, and your recommendations are important to us.
Jean O.
Jean_Intel
Hello LynxRufus,
We hope you are doing fine.
Best regards.
Jean O.
