Intel® ARC™ Graphics
3324 Diskussionen
Red Dead Redemption 2 - inevitable crashes after 5-10 min, FSR 2.0 broken
TradingToni
Einsteiger
7.228Aufrufe
Hello there,
i got my A770 yesterday and tried to play RDR2 with the newest drivers 4311 and the one driver version before that.
Sadly the game crashes everytime. After about 5-10 min. my screen goes black and only with a hard restart iam able to get accsess to my PC again.
The first time i had the crashes error messages came up (all the time different ones, but it did not made a note what code/message was standing there). After i played with some settings the error messages was gone, because the whole system now just goes dark. But the crashes take longer to appear (about 10 minutes into the game).
I restartet the game about 15 times with differnt solutions applied to solve the problem, sadly nothing is working.
My PC specs are not a concern:
i9 13900K
DDR5 32 GB 5200mhz
Western Digital m.2 nvme 2TB
Another finding i made: after i updated to the new beta driver 4311 FSR 2.0 is broken.  Its a blurry mess, i dont know how to describe it. This was not the case with the prior driver. I know FSR is not your software solution but it seems this driver is the cause.
I hope a solution can be found, i really like this game.
Beschriftungen (1)
3 Antworten
Jean_Intel
Mitarbeiter
7.137Aufrufe
Hello TradingToni,
Thank you for posting on the Intel️® communities. We would be more than glad to help you solve your issues.
To better comprehend your issue, please provide us with the following:
  • Does the RDR2 problem persist on previous driver versions?
  • Which driver version have you tried?
  • Is the FSR issue present in different games?
  • What are the games distribution service? ( Blizzard, Epic, Origin, Steam, Xbox, Ubisoft connect).
  • Is this the first graphics adapter installed on your system?
  • Share a video showing the RDR2 issue you are experiencing and the graphics settings you use.
  • Create a system report using the following applications:
  • Intel System Support Utility (Intel SSU)
    • Download the Intel SSU
    • Open the application and click "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
  • Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Jean_Intel
Mitarbeiter
7.113Aufrufe
Hello TradingToni,
We hope you are doing fine.
Jean O.
Jean_Intel
Mitarbeiter
7.075Aufrufe
Hello TradingToni,
Best regards.
Jean O.
Antworten
