Intel® ARC™ Graphics
3310 Discussions
Sackboy™: A Big Adventure graphics memory leak bug
DanSun
Nouveau contributeur I
7 713 Visites
If you play Sackboy™: A Big Adventure and use ray tracing, you will experience a sharp drop in game performance as the GPU memory exceeds 15 to 16 gigabytes or more when you play another stage after clearing a stage.WW.jpg
https://community.intel.com/t5/Intel-ARC-Graphics/Sackboy-A-Big-Adventure-Bug/m-p/1456659#M1735
For system details, please refer to this link
The graphics driver is 4125.
0 Compliments
22 Réponses
Hugo_Intel
Employé
6 657 Visites
Hello DanSun
Thank you for posting on the Intel® ARC™ Graphics Communities. I am sorry to hear that you are experiencing performance issues on Sackboy™: A Big Adventure. Please let us know the following information:
  • Share a short video showing this issue with the performance information in English.
  • Share screenshots of the in-game graphics settings in English.
  • Is Resizeable Bar enabled in your system?
  • What steps can be followed to replicate this problem?
  • I did not find an Intel® System Support Utility log file on the link that you shared, please create and attach it to get more information about your system.
Hugo O.
0 Compliments
DanSun
6 647 Visites
If you refer to the address link I posted, I think you don't have to ask that question because most of what Intel asked for was done.
The screen shot uses 15 gigabytes of GPU memory as shown in the picture, and the game slows down to about 4-5 frames.
0 Compliments
Hugo_Intel
Employé
6 628 Visites
Hello DanSun
Thank you for letting us know. We already got most of the information from your previous thread, however, in order to further assist with this issue we still need to know the following from my previous post as this is missing information from the previous thread:
  • Was Resizable BAR enabled on your system?
  • We need the Intel® System Support Utility log to get more information about your system configuration.
  • Steps to replicate the issue, does the issue happens right after enabling RayTracing? Is it specific to a certain area?
Hugo O.
0 Compliments
Hugo_Intel
Employé
6 599 Visites
Hello DanSun
I hope you are doing fine.
Hugo O.
0 Compliments
DanSun
6 593 Visites
a: Yes I used a resize bar
a: In the past, I sent a report by e-mail about anno1800 memory problem, but it is inconvenient to send it again.
a: With ray tracing, this problem occurs in all areas. After clearing the first stage, these symptoms get worse.
0 Compliments
Andres_Intel
Employé
6 554 Visites
Hello DanSun,
Thank you for your response, it has been really helpful.
We completely understand that you are not able to provide us with the Intel® System Support Utility log, but that we help us to speed up the process and for further investigation in case we need it.
Please answer the following questions to have a better understanding:
  • What are the motherboard make and model and BIOS version?
  • What is the processor model?
  • What is the Operating System version?
Andres P.
0 Compliments
DanSun
6 540 Visites
0 Compliments
Andres_Intel
Employé
6 506 Visites
Hello DanSun,
Thank you for your answer, it was very helpful.
Please follow the steps below and let us know the results:
  • Is Resizable Bar enabled?
  • Some days ago we released a new graphics driver version 31.0.101.4146 you can download it accessing the following link:
https://www.intel.com/content/www/us/en/download/726609/intel-arc-iris-xe-graphics-whql-windows.html?
For installation steps on: https://www.intel.com/content/www/us/en/support/articles/000005629/graphics.html
Andres P.
0 Compliments
Hugo_Intel
Employé
6 471 Visites
Hello DanSun
We are following up with this thread. I understand that Resizable BAR is enabled on this system. Could you please share with us if you were able to test the previously recommended driver?
Hugo O.
0 Compliments
Hugo_Intel
Employé
6 443 Visites
Hello DanSun
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
0 Compliments
Hugo_Intel
Employé
6 389 Visites
Hello DanSun
We would like to make sure if disabling virtual memory page file still works to improve the behavior related to this issue as you have reported in previous threads. Please let us know.
Hugo O.
0 Compliments
DanSun
6 361 Visites
If you turn off the virtual memory, the game will force quit after using 8~11 gigabytes of video memory.
That's a problem too, but the game uses an unusually large amount of video memory.
0 Compliments
Hugo_Intel
Employé
6 329 Visites
Hello DanSun
Thank you for the information. So to make sure doesn't enabling the virtual memory work as a workaround for this issue? Or, Was that a totally different issue from the one that you are reporting on this thread?
Hugo O.
0 Compliments
DanSun
6 315 Visites
"When you come to Intel, talk the Intel way"
Did Intel play the game Sackboy™: A Big Adventure?
0 Compliments
DanSun
6 292 Visites
Raja Koduri has resigned.
Until the vision of the future Intel GPU is clear, I will not be active either.
Thank you for your hard work.
0 Compliments
Hugo_Intel
Employé
6 275 Visites
Hello DanSun
In regards to the issue that involves this thread, I want to let you know that we tested the game and were not able to reproduce the issue you reported on previous threads. This is why we wanted to confirm if the previous workaround that you reported keeps working on the game or if the issue is different.
I understand your position in regard to recent news, please let us know if you would like to continue troubleshooting and please note that plans for Intel® Arc™ GPUs have not changed.
Hugo O.
0 Compliments
DanSun
6 248 Visites
It seems that the use of ray tracing is an excessive use of graphics memory.
If you're not using ray tracing, there's no problem, but ray tracing uses an unreasonably large amount of graphics memory.
Please answer whether or not Intel has a problem with the use of ray tracing.
Currently in Korea, Raja Koduri's resignation is highly welcomed and expected. Now, Intel has the expectation that Arc graphics will solve the problem and make a normal graphics card, and it is criticizing Raja Koduri, who left the company.
What I'm worried about is that the direction of arc graphics recently shown by Intel has recently changed so much that it seems to be giving up the business, so I'm concerned.
I have been using Radeon for over 20 years, and I boldly went over to Intel Arc with the hope that Intel would become a new leader and change in the current graphics card market. I hope that Intel will not give up the graphics business as in the past and will be a company that changes the aggressive and aggressive market.
0 Compliments
Hugo_Intel
Employé
6 170 Visites
Hello DanSun
Thank you for the clarification on this issue. There is no general issue with Ray tracing and our GPU, so we will continue checking this title specifically and see if it can be reproduced. Thank you for the information provided., I will get back to you as soon as I have more information.
Hugo O.
0 Compliments
Hugo_Intel
Employé
5 481 Visites
Hello DanSun
Thank you for your patience on this matter. Based on our testing and development this memory leak issue should no longer occur after driver version 31.0.101.4644. Please update to the latest version and share with us whether you still experience this problem, we would appreciate your feedback.
Hugo O.
0 Compliments
Hugo_Intel
Employé
5 446 Visites
Hello DanSun
We wanted to follow up on this issue. Did you have the chance to test our latest driver version 31.0.101.4644? Please share your feedback with us and let us know if the issue still happens to you.
Hugo O.
0 Compliments
Répondre
