Intel® ARC™ Graphics
3300 ディスカッション
Screen flickering artifacts Arc A380
Mynameforum
新規コントリビューター I
1,804件の閲覧回数
Just reporting again that im still having screen artifacts. Sparkle A380 Elf.
Driver gfx_win_101.6972.
When the game in borderless mode and somethin on top of it - artifacts appears
Firefox picture in picture mode boosts artifacts very much.
Windows explorer has very rare artifact appearance.
Check the video.
There no problem with games if you dont place anythin on top of the game window.
Card works good no crashes etc. Everydays usage.
My previous thread/report for additional information.
https://community.intel.com/t5/Intel-ARC-Graphics/New-driver-arifacts-Arc-A380/m-p/1696704#M26036
0 件の賞賛
13 返答(返信)
Mynameforum
新規コントリビューター I
1,798件の閲覧回数
If i disable Smooth Sync in the Intel Graphics Software the issue dont appear.
I checked two times. Im 100% sure.
RandyT_Intel
モデレーター
1,730件の閲覧回数
Hi @Mynameforum,
In the meantime, please try to follow the steps outlined in the article. Let me know if there are any changes, and kindly provide an updated SSU log report so I can review the overall system configuration.. I will begin investigating the issue and attempt to replicate it on our end. I'll post an update here or notify you directly once there are any developments. If I need further details, I'll reach out to you here. I appreciate your patience as I work on this matter.
Randy T.
Mynameforum
新規コントリビューター I
1,708件の閲覧回数
Updated to latest driver gfx_win_101.6989. Used DDU and then clean install.
Checked its same. Smooth Sync causing those artifacts.
RandyT_Intel
モデレーター
1,608件の閲覧回数
Hi @Mynameforum,
Could you please provide the download link for the game you tested? I’d like to check the issue on my end, as we’ve already applied the known workarounds. If the problem is indeed caused by the Smooth Sync feature, I’ll investigate further and report back with my findings once the analysis is complete.
Randy T.
Mynameforum
新規コントリビューター I
1,567件の閲覧回数
The game Tiny Tina's Wonderlands.
https://store.steampowered.com/app/1286680/Tiny_Tinas_Wonderlands/
Firefox version that in the video 138.0.1 (32-bit).
RandyT_Intel
モデレーター
1,537件の閲覧回数
Hi @Mynameforum,
Thank you for providing the information.
As part of our isolation steps before replicating the issue, may I kindly ask you to try updating your BIOS to the latest version: 10.42 (dated 2025/04/18). After updating, please check if it makes any difference with the graphics driver installation issue.
If you're unsure how to update the BIOS, I recommend contacting your system manufacturer for guidance on the installation process.
Artifacts and Flickering Screen When Scrolling Using a Browser on...
Let me know once you've tried this, so we can proceed accordingly.
Randy T.
Mynameforum
新規コントリビューター I
1,458件の閲覧回数
The latest bios is a beta and i has latest non beta bios already. Dated 2024/1/25.
The manufacturer says no need to update
*ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system.
I have two pinnacle ridge cpus.
I found that different visual effects setting has impact on artifact appearing. Set it like mine on the screenshot or use "adjust for best performance".  And disable transparency.
Then test in the lab. Also i dont use hardware acceleration in firefox.
RandyT_Intel
モデレーター
1,416件の閲覧回数
Hi @Mynameforum,
Let me investigate this further. I’ll post an update here as soon as more information becomes available.
Randy T.
RandyT_Intel
モデレーター
1,183件の閲覧回数
Hi @Mynameforum,
To help us recreate the issue you've encountered, could you please provide the screenshot of game settings you are currently using?
Once we have this information, we’ll proceed with further testing.
Randy T.
Mynameforum
新規コントリビューター I
1,168件の閲覧回数
Its not matter bacase it appears in many other games. You can use medium preset.
But also its important Vsync in the game settings should be off. Because otherwise smooth sync will not work.
RandyT_Intel
モデレーター
1,118件の閲覧回数
Hi @Mynameforum,
I see. Have you had a chance to test the games using the latest version 32.0.101.7026 (WHQL Certified)? Please let me know if you notice any changes in system behavior.
Randy T.
Mynameforum
新規コントリビューター I
827件の閲覧回数
Yes. Updated to 32.0.101.7026 (WHQL Certified). Didnt help.
Here Oblivion Remastered same artifacts. You should look for games which can disable vsync in borderless mode. Because not all of them can. And then apply Smooth Sync in the driver.
Im using white moving bar in the video to see if sync works and wich one.
RandyT_Intel
モデレーター
778件の閲覧回数
Hi @Mynameforum,
Thanks for the update. I need to look into this issue further and investigate the vsync/borderless mode behavior you're describing. I'll get back to you once I have more information.
Randy T.
返信
