Intel® ARC™ Graphics
3363 Discussions
Showing Arc Control by ALT+I may reset the app to defaults.
Sakura329
When I show "Arc Control" by "ALT+I" or from the system tray icon in another window mode different from the last time shown, the app is reset to defaults.
Steps to reproduce:
0. Ensure that "Window Mode" is set to "Desktop and Overlay".
1. Show "Arc Control" in "desktop mode".
2. Add games manually in "Game library".
3. Close "Arc Control" by the close button.
4. Show "Arc Control" by "ALT+I".
5. Added games will not be shown in "Game library".
I have experienced this issue on version 1.68.4938.6 and 1.69.5033.3.
Andres_Intel
Hello Sakura329,
Thank you for your patience.
I want to let you know that this issue has been fixed in our latest driver 31.0.101.5081. Please follow the steps below and let me know the results:
Andres P.
Andres_Intel
Hello Sakura329,
Thank you for posting on the Intel communities. I am sorry to hear that you are having issues with your Intel® Arc™ Control Software, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
  • I see you shared the steps to reproduce, to have a visual example, take a video of the issue.
  • What troubleshooting steps have you done?
  • Did you make hardware or software changes when the issue started?
  • When did the issue start?
Andres P.
Sakura329
The issue started after I installed Graphics Driver 31.0.101.4369. I made no hardware change before and after the issue started. I uninstalled old drivers with DDU, installed OEM drivers downloaded from MSI(30.0.100.9805) and Asrock(31.0.101.3430), then installed the latest driver at that time downloaded from Intel(31.0.101.4369). I took 2 videos of notifications settings being reset by "ALT+I" hotkey and "Open Arc Control" system tray menu respectively.
Andres_Intel
Hello Sakura329,
Thank you for your response, all the information provided has been really helpful.
  • Uninstall Intel® Arc™ Control
  1. Press the Windows key.
    1. Click on settings.
    2. Select Apps and then select Apps & features.
    3. Search for Intel® Arc™ Control software.
    4. Click on it and select the option to uninstall.
Let me know the results.
Andres P.
Sakura329
I followed the instructions, but the issue still persists. I uninstalled Arc Control first, then I have installed Graphics Driver 31.0.101.4514.
Andres_Intel
Hello Sakura329,
Thank you for your answer, and for completing the steps.
I will start with an investigation to provide you with the next steps, as soon I have further information I will let you know.
Andres P.
Andres_Intel
Hello Sakura329,
Thank you for your time.
We still working on the investigation, please follow the steps below to get the Intel® Arc™ Control logs:
  1. Go to File Explorer
  2. Go to C:\Users\<your_username_here>\AppData|Local\Intel\IGN\logs
  3. Attach the files you find there
Andres P.
Sakura329
I took these logs as follows. I started "Intel Arc Control" with "Desktop" window mode, modified notification settings and once closed the app, then showed the app by "ALT+I" and made sure that notification settings had been reset. At last I exited the app.
Andres_Intel
Hello Sakura329,
Thank you for your response, it has been very helpful.
I will continue with the investigation, as soon I have further information I will let you know.
Andres P.
Andres_Intel
Hello Sakura329,
Andres P.
Sakura329
I already updated the graphics driver to version 31.0.101.5081. I'm happy to know that the issue has been fixed completely. Thank you for your hard work.
Andres_Intel
Hello Sakura329,
Thank you for letting me know the results.
Happy to hear that the issue is fixed after updating the graphics driver to version 31.0.101.5081, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
