Intel® ARC™ Graphics
3297 Discussions
THE CREW MOTORFEST - INTEL ARC A770 and A750 ISSUES
Dedsec10
Currently facing issues on Crew Motorfest, as GPU encounters a significant amount of FPS drop in games or the GPU cannot be found while launching even on the latest drivers. Although, the every condition in GPU was checked and everything was good.
  • Latest drivers updated
  • Resizable BAR is on
  • set to the maximum resolution
  • No other applications running in the background
  • launched via Ubisoft connect
Please keep me posted!!
Thank you if you get the solution!
Dedsec10
Mike_Intel
Hello Dedsec10,
  1. Was it working fine before?
  2. What was the last change before the issue started?
  3. Can you share the screenshot of the error that the GPU cannot be found?
  4. If you can still enter the menu of the game, can you take the screenshot of the Graphics settings?
  5. Can you also provide a video of the performance?
  6. Please help generate the SSU logs of your system for me to review the drivers installed. Please refer to the link below on how to generate the logs.
Michael L.
Dedsec10
Hello Mike_Intel,
Thank you for acknowledging the message.
I need your super assistance on the problem I'm facing lately.
I will guide you through your answers step-by-step.
1. Yes it was working fine way before.
2. The last change I performed, updated to latest drivers and cleared the previous documents.
3. attachment has been added below
4. Sure, attachment is added below
5. Okay, I'll try to upload the video.
Mike_Intel
Hello Dedsec10,
Michael L.
Mike_Intel
Hello Dedsec10,
Thank you for the update.
While waiting for the SSU and video, let me also recommend the following steps and tell me if there will be improvements.
  1. Try to update the BIOS of your motherboard to the latest if the BIOS is not yet updated.
  2. Kindly try to update the driver using DDU method. Please refer to the links below for the link of the latest driver and steps for DDU.
How to Use the Display Driver Uninstaller (DDU) to Uninstall an...
Intel® Arc™ & Iris® Xe Graphics - Windows*
Michael L.
Mike_Intel
Hello Dedsec10,
Michael L.
Mike_Intel
Hello Dedsec10,
I am sending another follow up to check if you already tried our recommendations.
Michael L.
