Intel® ARC™ Graphics
3301 Discussions
Task manager resources use
Saabjock
Why is ARC Control using so many resources in Task Manager?
I just launched it to see what was running at startup and sure enough, there are multiples of various components...most absolutely hogging into the system resources.
Andres_Intel
Hello Saabjock,
Thank you for posting on the Intel communities. I see in the screenshot that Intel® Arc™ Control is using many resources when starting up, I will be mote than happy to help you.
In order to enhance comprehension of the circumstances, kindly respond to the following inquiries:
  • Have you noticed what resource Intel® Arc™ Control using the most? For example the memory RAM, processor, etc.
  • To check your hardware and software information, can you run and attach the  Intel® System Support Utility for Windows (SSU) report? You can find the steps on the link How to get the Intel® System Support Utility Logs on Windows.
Andres P.
Saabjock
Here is the Intel System Support Utility report.
Andres_Intel
Hello Saabjock,
Thank you for all the information provided.
I checked in the Intel® SSU that you system is up to date, please follow the steps below and let me know the results:
  1. Uninstall Intel® Arc™ Control
  2. Clean install the graphics driver with Display Driver Uninstaller (DDU). For guidance, How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver.
  3. Install the graphics driver 31.0.101.5081.
Andres P.
Andres_Intel
Hello Saabjock,
Were you able to update the graphics driver to version 31.0.101.5081 to check if the behavior changes?
Andres P.
Andres_Intel
Hello Saabjock,
Andres P.
