Intel® ARC™ Graphics
3363 Diskussionen
The frequency in the game drops
Raifart
Anfänger
4.097Aufrufe
1. Good day to all, and again the same problem the video card drops the frequency and nothing works to make it go from 400 MHz to a higher one! in the game!!!, perhaps this is due to the fact that I raised the voltage and frequency, I could not accumulate sufficient statistics, but for now the fact is - when overclocking the video card (and this is a separate incomprehensible story since the settings do not respond to the card's operation at all, I am really tired trying to set up normal operation) so when overclocking this definitely happens - in the middle of the game process the frequency drops to 400 MHz and even attempts to adjust the graphics in the game do not help (earlier it randomly helped) and after 2 minutes, for example, it itself accelerated again or may not accelerate, the temperatures are normal, the fan is set to 100% at 70C degrees. A very crooked driver!!!!!! 2. and the frequencies are still displayed incorrectly!!! No matter how I set up the parameters, the frequency both in idle and in the game is 9.3 frames per second!!!!
31 Antworten
ArchieD_Intel
1.743Aufrufe
Hi Raifart,
Thank you for your update. I've sent an email to your active email address for the settings that I needed.
Please check both your Inbox and Spam folder for my email, and once received, kindly acknowledge it.
Archie D.
Raifart
Anfänger
537Aufrufe
overclocking settings
Raifart
Anfänger
534Aufrufe
and what is very inconvenient is that it is not clear which setting has what effect, since they can overlap each other, it is not clear where the -105 frequency units are counted from.... what units of measurement (probably MHz, but this is not obvious, since it is not clear what frequency should be at 0 MHz)
- The video card never withstands 100% power, how can this be, that is, it is obviously weaker than it should be!?!?!?!?
and in the "Advanced" mode it is generally impossible to overclock!
- Now why did I turn on overclocking at all:
Because the declared power of 180 W is never achieved, the video card seems to be strangled (slowed down) This is completely incomprehensible!
ArchieD_Intel
525Aufrufe
Hi Raifart,
Thank you for your feedback. I will be investigating this and replicating the issue using the settings that you're using. I will be updating you for my findings and if a solution is available. Thank you for your patience.
Archie D.
KoN
Anfänger
499Aufrufe
Using ray tracing will drop frames rates, drivers are not quite there yet and also if looking at desktop frames and freq will drop as the card isn't needed to use full power and  this is normal for good card to adjust .
Raifart
Anfänger
486Aufrufe
I understand this perfectly, but it keeps the frames in the region of acceptable 55-60 fps? and then it can drop out of the blue to 5-10 fps. is this also normal??
Ernesto_C_Intel1
445Aufrufe
Hi @Raifart
I hope this message finds you well. I am reaching out to you on behalf of our technician, Archie, regarding your ongoing case.
Please be assured that we are diligently working to identify the root cause of the issue you are experiencing. We kindly ask for your patience as we continue our investigation to ensure a thorough resolution.
I will provide you with an update as soon as possible. In the meantime, if you have any questions or require further assistance, please do not hesitate to contact me.
Thank you for your understanding and cooperation.
Ernesto C.
Ernesto_C_Intel1
231Aufrufe
Hi @Raifart
I sincerely apologize for the delayed response regarding the performance issues you are experiencing with your graphics card. I understand how frustrating technical difficulties can be, and I recognize that timely communication is essential.
I want to assure you that your case remains a high priority. I am currently conducting a thorough investigation into the low performance issues you've reported to ensure that I provide you with the most accurate and effective solution. This additional analysis will help me better understand the root cause and recommend the appropriate resolution steps.
I will provide you with a comprehensive update as soon as my investigation is complete. In the meantime, please don't hesitate to reach out if you have any additional questions or concerns.
Thank you for your patience and understanding as we work to resolve this matter promptly.
Ernesto C.
Raifart
Anfänger
219Aufrufe
Hello, thank you for continuing to work on the problem, but I have new difficulties, this time with the SolidWorks 2023 program, when rotating the part, artifacts appear,
1. surfaces marked with the number "1" should be transparent at this moment
2. however, partially transparent if they are behind other transparent elements
3. and partially transparent!
Ernesto_C_Intel1
89Aufrufe
Hi @Raifart
Regarding your new concern, it would be to create a separate thread for this issue so that we can focus our effort in addressing the issue you've initially raised on this thread.
Ernesto C.
Ernesto_C_Intel1
89Aufrufe
Hi @Raifart
I'm pleased to inform you that a fix for this specific issue has been implemented in game patch 1.62. To ensure optimal performance and compatibility, I also recommend updating to the latest graphics driver version 32.0.101.8132 WHQL Certified.
  1. Please ensure your game is updated to patch 1.62 or later
  2. Install graphics driver version 32.0.101.8132 WHQL Certified (Latest)
After completing these updates, please test the functionality and let us know if you continue to experience any issues. We're here to assist you further if needed.
Thank you for your patience, and we appreciate your continued support.
Ernesto C.
Antworten
