Intel® ARC™ Graphics
3307 Discussions
The game forcibly crashes to the desktop when using the ultra graphics option in Forza Horizon 5
DanSun
The game forcibly crashes to the desktop when using the ultra graphics option in Forza Horizon 5 Steam.
https://www.youtube.com/watch?v=nETQGtt024k&t=2217s
Watch the youtube video at 34:22 for reference
This is true even with the latest drivers.
Only HIGI graphics options are available, and if you raise more than that, the game will be forcibly terminated.
AMD CPU 5950X
AUSU Crosshair vii (Bios4901)
X470 Drivers 4.11.15.342
Ram 32gb
Windows 11 22h2
intel ARC A770LE 16Gb (31.0.101.4034)
Resizable BAR On
NUGGETZ
i have the same issue. did u get the fix for this? im on the xbox app
DanSun
This was a problem that occurred when the virtual memory function was turned off in Windows. The problem also occurs with many games. Therefore, be sure to turn on Windows virtual memory.
NUGGETZ
DanSun
https://wccftech.com/how-to/how-to-move-your-pcs-virtual-memory-to-a-separate-drive-on-windows-10/
Please refer to the explanation here Instead of just following the instructions here, you should do the following in C: please refer to this
NUGGETZ
NUGGETZ
i just did this and it still doesnt work
NUGGETZ
NUGGETZ
Hello I tried this again and it worked. I had to click on custom size and manually set the memory on HDD. Thanks
Bandit8623
New Contributor III
Did you guys disable page file manually before this?  because the default windows behavior is pagefile enabled.  Even with 32Gb of ram the pagefill should still be activ(system managed)
https://www.anoopcnair.com/enable-disable-memory-compression-on-windows-11/#:~:text=5.-,In%20the%20Administrator%3A%20Windows%20PowerShell%2C%20you%20need%20to%20execute%20the,device%20to%20apply%20the%20changes.
also could tinker with memory compression.
at anyrate if raising the pagefile size works it seems its a game bug for sure
