Intel® ARC™ Graphics
3294 讨论
The game forcibly crashes to the desktop when using the ultra graphics option in Forza Horizon 5
DanSun
新分销商 I
2,254 次查看
The game forcibly crashes to the desktop when using the ultra graphics option in Forza Horizon 5 Steam.
https://www.youtube.com/watch?v=nETQGtt024k&t=2217s
Watch the youtube video at 34:22 for reference
This is true even with the latest drivers.
Only HIGI graphics options are available, and if you raise more than that, the game will be forcibly terminated.
AMD CPU 5950X
AUSU Crosshair vii (Bios4901)
X470 Drivers 4.11.15.342
Ram 32gb
Windows 11 22h2
intel ARC A770LE 16Gb (31.0.101.4034)
Resizable BAR On
0 项奖励
9 回复数
NUGGETZ
初学者
2,106 次查看
i have the same issue. did u get the fix for this? im on the xbox app
0 项奖励
DanSun
新分销商 I
2,096 次查看
This was a problem that occurred when the virtual memory function was turned off in Windows. The problem also occurs with many games. Therefore, be sure to turn on Windows virtual memory.
0 项奖励
NUGGETZ
初学者
2,087 次查看
How to turn it on?
0 项奖励
DanSun
新分销商 I
2,073 次查看
https://wccftech.com/how-to/how-to-move-your-pcs-virtual-memory-to-a-separate-drive-on-windows-10/
Please refer to the explanation here Instead of just following the instructions here, you should do the following in C: please refer to this
0 项奖励
NUGGETZ
初学者
2,053 次查看
0 项奖励
NUGGETZ
初学者
2,033 次查看
i just did this and it still doesnt work
0 项奖励
NUGGETZ
初学者
2,030 次查看
getting this error
0 项奖励
NUGGETZ
初学者
1,979 次查看
Hello I tried this again and it worked. I had to click on custom size and manually set the memory on HDD. Thanks
0 项奖励
Bandit8623
新分销商 III
1,970 次查看
Did you guys disable page file manually before this?  because the default windows behavior is pagefile enabled.  Even with 32Gb of ram the pagefill should still be activ(system managed)
https://www.anoopcnair.com/enable-disable-memory-compression-on-windows-11/#:~:text=5.-,In%20the%20Administrator%3A%20Windows%20PowerShell%2C%20you%20need%20to%20execute%20the,device%20to%20apply%20the%20changes.
also could tinker with memory compression.
at anyrate if raising the pagefile size works it seems its a game bug for sure
0 项奖励
回复
