Intel® ARC™ Graphics
3298 讨论
Unable to turn on variable refresh rate
wsuser
初学者
3,433 次查看
Battery backup appears to be very poor on my Intel NUC X15 LAPAC71G
I see the refresh rate is defaulting to 144 hertz and I am unable to reduce that to basic like 60 hz, to improve on my battery backup time.
Also Unable to turn on variable/dynamic refresh rate as well.
Note: I have already tried multiple options, updated bios, drivers etc.,
0 项奖励
15 回复数
Mike_Intel
主持人
3,387 次查看
Hello wsuser,
For us to further check this, please help provide the following details:
  1. Is it working fine before?
  2. Did you change any settings before the issue started?
  3. Can you share some screenshots of the issue?
Michael L.
0 项奖励
wsuser
初学者
3,384 次查看
Its a newly purchased laptop.
No setting changed.
0 项奖励
MUC
名誉分销商 I
3,343 次查看
Please create a Report for Intel Graphics Drivers and attach the file here.
0 项奖励
wsuser
初学者
3,296 次查看
See attached. thanks
0 项奖励
Mike_Intel
主持人
3,328 次查看
Hello wsuser,
Thank you for the quick reply.
Kindly generate the SSU logs of your system for me to further check this issue.
https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
Michael L.
0 项奖励
wsuser
初学者
3,296 次查看
Please find attached. Neither integrated graphics nor the dedictaed GPU is supporting custom/variable refresh rate. It is fixed to 144hz
0 项奖励
MUC
名誉分销商 I
3,263 次查看
The built-in laptop screen is a panel from the manufacturer BOE Technology with the type designation NV156FHM-N4G. According to the data that the graphics driver receives from the display (EDID), this panel does not support variable synchronization but only a single fixed resolution and refresh rate: 1080p @ 144 Hz.
To get the most out of the graphics hardware, you can connect an external monitor with VESA AdaptiveSync to the Thunderbolt port. With this cable, for example, you can send a DisplayPort HBR3 signal (also with DSC) from your LAPAC71G.
Right side of the device:
0 项奖励
wsuser
初学者
3,200 次查看
Its disappointing to hear that. Any alternate option?
My battery backup is hardly an hour or so even with normal browsing and usage. How to improve that?
Also when you say, that I can use the external monitor which accessory mentioned, how does that help? Can that improve on my battery back time.
0 项奖励
Mike_Intel
主持人
3,251 次查看
Hello wsuser,
I have reviewed the SSU logs and found out that your drivers and BIOS is not updated.
Please try to Update them and check if there will be changes.
Here are the BIOS and driver download links:
https://www.intel.com/content/www/us/en/download/747246/bios-update-acadl357-for-the-intel-nuc-x15-laptop-kits-lapac71g-lapac71h.html
https://www.intel.com/content/www/us/en/download/737254/driver-pack-for-the-intel-nuc-x15-laptop-kit-lapac71h-lapac71g.html
Kindly open this link for the steps on how yo update the BIOS.
Michael L.
0 项奖励
wsuser
初学者
3,200 次查看
Why do you say that. Based on the SSU output also my BIOS is already uptodate.
At version ACADL357.0065.2024.0409.1723 which is the latest available.
https://downloadmirror.intel.com/821091/AC_0065_ReleaseNotes.pdf
0 项奖励
Mike_Intel
主持人
3,064 次查看
Hello wsuser,
Have you also tried to install the latest driver package for your laptop?
Michael L.
0 项奖励
wsuser
初学者
3,019 次查看
All my drivers are already up-to-date.
Used intel support utility/assistant to validate the same.
0 项奖励
Mike_Intel
主持人
2,983 次查看
Hello wsuser,
Just to clarify, the main issue here is the weak performance of the battery?
Can you provide the screenshot of the power scheme of your system?
The power scheme option can be found at: Control Panel --> Power Options. The power scheme would include: Balanced, Power saver, High Performance or Ultimate Performance.
Michael L.
0 项奖励
Mike_Intel
主持人
2,840 次查看
Hello wsuser,
Michael L.
0 项奖励
Mike_Intel
主持人
2,683 次查看
Hello wsuser,
I am sending another follow up on the information that I requested.
Michael L.
0 项奖励
回复
