- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Battery backup appears to be very poor on my Intel NUC X15 LAPAC71G
I see the refresh rate is defaulting to 144 hertz and I am unable to reduce that to basic like 60 hz, to improve on my battery backup time.
Also Unable to turn on variable/dynamic refresh rate as well.
Note: I have already tried multiple options, updated bios, drivers etc.,
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello wsuser,
For us to further check this, please help provide the following details:
- Is it working fine before?
- Did you change any settings before the issue started?
- Can you share some screenshots of the issue?
Michael L.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Its a newly purchased laptop.
No setting changed.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello wsuser,
Thank you for the quick reply.
Kindly generate the SSU logs of your system for me to further check this issue.
https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
Michael L.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Please find attached. Neither integrated graphics nor the dedictaed GPU is supporting custom/variable refresh rate. It is fixed to 144hz
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
The built-in laptop screen is a panel from the manufacturer BOE Technology with the type designation NV156FHM-N4G. According to the data that the graphics driver receives from the display (EDID), this panel does not support variable synchronization but only a single fixed resolution and refresh rate: 1080p @ 144 Hz.
To get the most out of the graphics hardware, you can connect an external monitor with VESA AdaptiveSync to the Thunderbolt port. With this cable, for example, you can send a DisplayPort HBR3 signal (also with DSC) from your LAPAC71G.
Right side of the device:
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Its disappointing to hear that. Any alternate option?
My battery backup is hardly an hour or so even with normal browsing and usage. How to improve that?
Also when you say, that I can use the external monitor which accessory mentioned, how does that help? Can that improve on my battery back time.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello wsuser,
I have reviewed the SSU logs and found out that your drivers and BIOS is not updated.
Please try to Update them and check if there will be changes.
Here are the BIOS and driver download links:
Kindly open this link for the steps on how yo update the BIOS.
Michael L.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Why do you say that. Based on the SSU output also my BIOS is already uptodate.
At version ACADL357.0065.2024.0409.1723 which is the latest available.
https://downloadmirror.intel.com/821091/AC_0065_ReleaseNotes.pdf
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello wsuser,
Have you also tried to install the latest driver package for your laptop?
Michael L.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
All my drivers are already up-to-date.
Used intel support utility/assistant to validate the same.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello wsuser,
Just to clarify, the main issue here is the weak performance of the battery?
Can you provide the screenshot of the power scheme of your system?
The power scheme option can be found at: Control Panel --> Power Options. The power scheme would include: Balanced, Power saver, High Performance or Ultimate Performance.
Michael L.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello wsuser,
Michael L.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello wsuser,
I am sending another follow up on the information that I requested.
Michael L.
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
