Intel® ARC™ Graphics
3299 Обсуждение
intel arc a770 16gb bifrost vram leak dayz
Jonnybads
Начинающий
6 464Просмотр.
Whenever I got to vorkuta on the Namalsk map I get really bad stutters and after about 4 hours my vram usage has climbed to around 14 gb of vram usage and is still climbing and the game becomes almost unplayable. Dayz is the only game i have the issues on. I've searched everything I can think of to find info on but it seems like I'm the only one with the issue or plays dayz with an arc card so I'm not actually sure if its the arc card. I am currently running driver .4887 and was installed with ddu in safe mode. this problem also exist5ed in 4885 and 4826
specs:
cpu- amd 5800x3d
mobo- asus TUF x570
ram- corsair 32gb LPX 3600
PSU- AGK 850w 80+ gold certified
windows 11 home 22h2
I play on the DayOne community servers which are lightly modded.
I didnt have this issue on my rx 6800 16gb with the same system specs.
I've tried everything I could to figure out the problem so this is the last resort. everything else i play runs fantasic
0 баллов
20 Ответы
Jonnybads
Начинающий
6 387Просмотр.
forgot to add this is on 1440p. and is installed on a m.2 nvme ssd
Andres_Intel
Сотрудник
6 323Просмотр.
Hello Jonnybads,
Thank you for posting on the Intel communities. As a gamer I understand how frustrating is to have memory leak issues with the Intel® Arc™ A770 Graphics while playing Dayz, I will be glad to help you.
To understand the situation in a better way, please answer the following questions:
Andres P.
Jonnybads
Начинающий
6 319Просмотр.
ill get it all posted tonight, will make sure to go on a 4 hour session to make sure to provide a good report. I 've used msi after burner to measure the vram usage, the uninstalled it completly incase that was causing issues as i really only wanted to it to monitor fps. then monitored it via task manager and again with arc control. same results.
for the settings if you need to recreate the issue, first set overall to high as this controls draw distance then make changes to the other settings. Just dayz things I guess lol. i would also recommending running to a big city to see how bad it stutters. runs like a charm outside of bigger cities but its a slide show in the cities. It may not be a gpu issue but my knowledge kinda ends with everything I've tried.
Jonnybads
Начинающий
6 319Просмотр.
here's the ssu
Andres_Intel
Сотрудник
6 274Просмотр.
Hello Jonnybads,
Thank you for your response, and for all the information provided it has been really helpful.
I will start with an investigation to provide you with the next steps and as soon I have further information I will let you know.
Andres P.
Andres_Intel
Сотрудник
6 263Просмотр.
Hello Jonnybads,
Thank you for your time.
We still working on the investigation, but now I have a couple of questions:
  • You mentioned you play on the DayOne community servers which are lightly modded. Is the issue still present if you play the base game no mods or another server with no mods?
  • What's the game store where you bought the game?
Andres P.
Jonnybads
Начинающий
6 261Просмотр.
The map I play isnt an official map. i have played on official servers on livonia map so completly unmodded and htough i didnt have it in me to play the map for 4 hours due to not knowing the map but when i made it to a decent size city/town the terrible stuttering still existed but outside of the cities/towns i would stay around the 350ish fps mark running the same settings.
I bought the game on steam. thats the only place i think you can get it for pc I believe
Andres_Intel
Сотрудник
6 253Просмотр.
Hello Jonnybads,
Thank you for keeping me informed.
I will continue with the investigation and as soon I have further details I will let you know.
Andres P.
Jonnybads
Начинающий
6 246Просмотр.
Ty very much, Im not used to getting actual support from a company so thank you very much. I do love this card and it runs just good for the games I play atleast except dayz  ofcourse, but its also dayz so sometimes its expected lol.
Andres_Intel
Сотрудник
6 239Просмотр.
Hello Jonnybads,
Thank you for your time, for us it is a pleasure to help you.
We continue to work on your case and in order to continue we would like to clarify a couple of things before proceeding with our research:
  • I understand you did not play the same amount of time in the official Day Z map, however, we would like to know if you observed the same behavior with the VRAM used climbing progressively or if it just had performance issues. Furthermore, I understand we insist on this, however, it is important to make sure it is also present in the base game, and it is also important to proceed with our testing.
We appreciate your time and help so far.
Andres P.
Jonnybads
Начинающий
6 234Просмотр.
Yes the vram did climb over the 50 minutes or so I played on official. it started at around 3000 mb of usage then climbed to about 7000 mb of usage over the 50 minutes I had played on the official map
Andres_Intel
Сотрудник
6 233Просмотр.
Hello Jonnybads,
Thank you very much for the clarification.
One more time will continue with the investigation before proceeding with the testing, I will be back with more information as soon as possible.
Andres P.
Jonnybads
Начинающий
6 119Просмотр.
hello,
was just following up to see if you were able to find where the problem may be. thank you very much
Andres_Intel
Сотрудник
6 029Просмотр.
Hello Jonnybads,
We still working on the investigation, and now we will start with the reproduction of the issue, as soon as I have the results I will let you know.
Andres P.
Jonnybads
Начинающий
6 012Просмотр.
that'll work, thank you so much for being so helpful.
Jonnybads
Начинающий
5 897Просмотр.
Just following up again seeing if any progress had been made
Andres_Intel
Сотрудник
5 892Просмотр.
Hello Jonnybads,
Thank you for your patience.
We still working on the reproduction of the issue, and we hope to have the results soon, I will let you know as soon I have them.
In the meantime, I want to let you know that last week we released a new graphics driver version 31.0.101.4900. Please perform a clean installation of it with the Display Driver Uninstaller (DDU), if you need guidance, on How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver.
Andres P.
Andres_Intel
Сотрудник
5 796Просмотр.
Hello Jonnybads,
Thank you for all your time.
We have been working on the investigation and we were able to reproduce it by testing different driver versions including version 31.0.101.4900.
Yesterday we released a new version 31.0.101.4952. Please clean install it with DDU, to check if there are improvements, if you still need guidance, remember you can use How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver.
Let me know the results.
Andres P.
Jonnybads
Начинающий
5 762Просмотр.
I installed the new driver and everything runs great now. The cities dont stutter like crazy anymore and the vram issue seems to be resolved. thank you so much
Andres_Intel
Сотрудник
5 759Просмотр.
Hello Jonnybads,
Thank you for your answer.
Happy to hear that your issue is fixed after clean installing the graphics driver to version 31.0.101.4952, we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
Ответить
