pasted from previous thread as i have tried the same steps with the same results:
Hi There,
I've just picked up early access to Le Mans Ultimate via Steam. Game won't progress past the initial loading screen, which appears to be an issue with ARC graphics cards. A number of users are having similar issues. Have tried:
Loading from Steam
Loading from .exe directly
Loading from .exe directly as an administrator
Uninstall and reinstall
Disable Windows Defender
Installing to different SSD (don't have a traditional HDD to try)
Validating install via Steam
Ensuring all drivers are up to date
Closing all non-essential programs
When attempting to load from steam:
Click Play
Play button turns blue and shows "Cancel"
Studio 397 logo flashes
Small window with Le Mans Ultimate V0.4000 in header bar opens
Small window with Le Mans Ultimate V0.4000 closes 1-2 seconds later
Blue "Cancel" button in Steam turns green, showing "Play" again
Same thing happens when loading directly from the .exe, except it does not trigger the Steam button.
I don't run an antivirus other than Windows Defender
No performance monitors such as Afterburner or Riva Tuner installed
No performance enhancements or overclocking of graphics card.
Computer specs:
Intel I7-13700k
Intel Arc A750
MSI mortar B760M
32Gb corsair RAM
Windows 11
1. Yes i have attached what happens below#
2. no errors in event log
3. N/A
4. attached
5. I did a DDU install yesterday, no difference
dump file is not uploading: "The attachment's lemansultimateu2ht7vq3.dmp content type (application/octet-stream) does not match its file extension and has been removed."
Hello Brian81,
Thank you for the update.
Can you send the dump files to me via direct message if you cannot attach it here?
I will wait for it for further investigation.
Michael L.
Hi Mike it says the maximum file size is 23mb but the dump file is larger even when compressed
Hello Brian81,
Can you try to upload it in any 3rd party site then send the link to me?
Michael L.
Hi mike, here is the attached file:
https://drive.google.com/file/d/1XxSpzc4RXHPy59ciNhuM4w2G8ATh7rqy/view?usp=sharing
Same issue Le Mans Ultimate crashes for me on Intel Arc A770 16GB all the time at 100% loading screen, it's really disappointing that one of the best sim racing games out there right now doesn't work properly on Intel GPUs...
Hello Brian81,
I will review the logs and post the response on this thread once it is available.
Michael L.
Hello Dluczko,
I just want to update you that we tried this here on our end, we've tested the 32.0.101.6647 WHQL Certified (Latest) and the reported issue does not happen. Kindly try the latest driver below and update me if you are still having the same issue:
https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Michael L.
Are you sure it doesn’t work? Because me and many others are having this issue and all I did was just get the game launch it then make a session and then it would load to 100% and freeze then crash, with default settings.
Daniel
Hello Dluczko,
Just to check, did you try to install this driver via DDU method?
Need to document this part since it is still not working on your end.
If you need assistance, please create a new thread for us to assist you on your own thread and gather the details of your systems.
Michael L.
Daniel
Hello Brian81,
I will further check this and post the response on this thread once it is available.
Michael L.
Update: 32.0.101.6651 still crashes the game
It looks like your Intel Arc A750 GPU might be causing compatibility issues with Le Mans Ultimate in early access. Here are some additional steps you can try:
Potential Fixes
Intel Arc drivers are improving rapidly, so ensure you're on the latest Game Ready driver (Intel's official site).
Some users have had better results rolling back to an older stable version.
Try launching the game with -dx11 or -dx12 launch options in Steam:
Right-click the game in Steam Library → Properties
Under Launch Options, enter:
diffCopyEdit-dx11or
diffCopyEdit-dx12
Open Intel Arc Control Panel and disable any overlays, resizable BAR, or enhanced sync settings.
Right-click the game .exe → Properties → Compatibility tab → Run in compatibility mode for Windows 10.
Navigate to:
makefileCopyEditC:\Users\YourUsername\AppData\Local\LeMansUltimate\logsSee if there are any crash logs that hint at a cause.
Run msconfig → Go to Services → Check Hide All Microsoft Services → Disable all unnecessary services → Restart PC and try again.
If none of these work, the issue is likely on Intel’s side, and you might need to wait for an updated driver or a patch from the game developers.
