Intel® ARC™ Graphics
3360 Discussions
interlaced resolutions
shiromar
I have a
sony bvm-d24
sony kd-34xbr960
i use these for gaming at native 1080i resolution.
I am currently using a 1080 ti to output to these, I'm working on a new build and the 1080 ti was the last GPU NVIDIA supported interlaced resolutions. I am considering using ARC if resolution could be set to 1080i.
Is this currently possible?
Jean_Intel
Hello shiromar,
Thank you for posting on the Intel️® communities. We understand that you are looking for information about whether or not the Intel® Arc™ Graphics support 1080i resolution.
We would like to further investigate this matter; please provide us with the following information:
  • What Intel® Arc™ Graphics are you planning to use?
  • What video connection will you use? Will it be HDMI to HDMI?
Jean O.
shiromar
I have no idea which gpu I plan to use. I need to know if it supports it or not.
Jean_Intel
Hello shiromar,
We hope you are doing fine.
Jean O.
shiromar
I replied to that, I am asking if any of the arc gpu support interlaced resolutions.
I listed a Sony bvm as one of the display devices. I can connect via bnc, vga, scart, on the Trinitron I can connect via HDMI DVI dp
Jean_Intel
Hello shiromar,
We will proceed to check the issue internally and post back soon with more details.
Jean O.
shiromar
Thank you, I look forward to your response
Jean_Intel
Hello shiromar,
We appreciate your patience.
We would like to let you know that the Intel® Arc™ Graphics supports interlaced mode as long as the display's panel supports it. However, it is important to mention that we can't check with the display manufacturer for further compatibility information.
Jean O.
Jean_Intel
Hello shiromar,
Best regards.
Jean O.
