Hello
Found the next prob.
It seems (of course clean install) the new install of *.4314 will not restore the settings in the ARC control center.
Recommend to use the app Display Driver Uninstaller (DDU) in safe mode.
btw cant see any changelogs for *.4314 on the webside from Intel. (only about Videocardz)
Hello exc0mmunicated
We were able to reproduce this issue. And we want to let you know that we are working to improve our driver installation process through the installer, at the moment we advise that you continue using DDU to do a clean installation of the driver.
Thank you fo reporting this issue to us and for your valuable feedback.
Hugo O.
Thank you for posting on the Intel® ARC™ Graphics Commnities. I am sorry you are experiencing issues after installing the latest driver on your system.
Just so we can have a better understanding of the issue do you mean that when doing a regular installation of the driver the settings in Intel® Arc™ Control don't get reset to default and when using DDU they do get reset to defaults, is this the issue and behavior you are experiencing?
Answering your last questions, the release notes are now posted on the driver download page, we apologize if there were issues previously
Hugo O.
Thank you for the information. Just to confirm, there was a new driver update version 31.0.101.4335, Could you please test the new driver and check if the same issue still happens?
Hugo O.
Hello Hugo
Sure, I've tried it.
Follow things with *.4335 will not restore in ARC Control Center to stock (by choose "clean install"):
Performance
- Fan Curve
Global settings:
- all
Menu settings:
- all
ThX
Chris
Thank you for letting us know. I will check this with our team and I will give you an update once I have more information.
Hug O.
Hugo O.
The pleasure is mine, Hugo.
I think it's great how you and the team work here.
IMO another important point for establishing Intel on the graphics card market.
Keep it going and Greetings;)
We're glad to know the information helped. Hopefully, it will help to inform other community members that might notice the same issue. Since the thread is now solved, we will close it. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Hugo O.
