Intel® ARC™ Graphics
3286 Discussions
low performance fps cyberpunk 2077 1.63
addelucas123
New Contributor II
Good afternoon
I have a problem with low fps performance of cyberpunk 2077, I have everything updated to the latest version 1.63 with the latest Intel Arc A770 16GB drivers with version 31.0.101.4669 with the clean installation through the Display Driver Uninstaller DDU programs, and I reinstalled and I can't get over 60 FPS activating in ultra quality with ray tracing activated ultra with Intel XeSS technology quality mode and I can't get over 60 FPS, it only shoots me 40 to 45 FPS and some areas 35 FPS, all drivers updated bios updated etc, and I must at least be able to shoot above 60 FPS with the 1920x1080p resolution, let's go FULL HD, I tried to put in low ray tracing and it gives 50 to 55 FPS with Intel XeSS quality, Let's go that totally unplayable and the Intel Arc A770 16GB graphics must outperform the RTX 3060 Ti in cyberpunk 2077 with modern API
I also want to keep in mind that the Intel Arc A770 graphics with the ultra setting and Intel XeSS in quality should go from 95 to 100 FPS, the other compotency like NVIDIA RTX 3060 Ti reaches 90 to 95, and finally Intel Arc A770 should go with the ultra configuration plus ultra ray tracing and intel xess must go at least 70 FPS all at 1080p let's go Full HD, because the other compotence NVIDIA RTX 3060 Ti borders on 63 to 65 FPS with a peak of 69 FPS, since the intel arc a770 must exceed 70 a 73 FPS since it is a little higher than that would be 5% performance
Jean_Intel
Hello addelucas123,
We appreciate that you followed our advice and opened another thread. We would be more than glad to help you with the low performance when playing Cyberpunk 2077.
Let us review the information you have shared with us, and we will further investigate this matter internally. We will post back as soon as we have more details about this issue.
Jean O.
addelucas123
New Contributor II
I wanted to ask, do you know if the performance of the Intel Arc A770 card in Cyberpuynk 2077 1.63 will improve or not or will the performance continue?
Jean_Intel
Hello addelucas123,
Thank you for your patience.
We have reviewed your information and forwarded the feedback to the relevant team. However, we cannot guarantee any updates or commitments.
Let us know if you have any other questions regarding your problem.
Jean O.
Jean_Intel
Hello addelucas123,
As we mentioned before, we have shared the feedback with the appropriate team. Unfortunately, we don't have more information that we can share, and we can't promise any outcome or estimated time.
Jean O.
Jean_Intel
Hello addelucas123,
We hope you are doing fine.
We have not heard back from you, so we will close this thread. Please note that we have shared the information with the appropriate team; unfortunately, we can't commit to an estimated time or specific outcome.
If you need more information, please submit a new question since this thread will no longer be monitored.
Best regards.
Jean O.
