Intel® ARC™ Graphics
3310 討論
problem with Apex legends when REBAR is activated in directx12
LUIS11
初學者
3,635 檢視
The problem with crashes in Apex with directx 12 is the RE-BAR
Any solution for this problem?
標籤 (2)
0 積分
7 回應
Andres_Intel
員工
3,568 檢視
Hello LUIS11,
Thank you for posting on the Intel communities. I will be more than happy to help you. Because you are experiencing crashes when using your Intel® Arc™ A750 Graphics with DirectX12 and Re-Bar enabled to play Apex Legends. In order to enhance comprehension of the circumstances, kindly respond to the following inquiries:
  • Is the graphics card an Intel Branded Card or is it of another brand? This is to know if the issue happens to a specific edition.
  • Does the issue also happen with DirectX11?
Andres P.
LUIS11
初學者
3,549 檢視
The graphics card is from the Intel brand
In directx11 that doesn't happen
Hugo_Intel
員工
3,502 檢視
Hello LUIS11
I noticed you are using an outdated version of the driver 31.0.101.4972, please uninstall the driver using Display Driver Uninstaller, once uninstalled, update to the latest version 31.0.101.5084 and check if the same issue happens.
Hugo O.
LUIS11
初學者
3,495 檢視
Sorry, the SSU file is old, but I do have the most recent version of the drivers.
Andres_Intel
員工
3,385 檢視
Hello LUIS11,
Thank you for your response and for sharing all that information.
Since the issue does not happen with DirectX11, we recommend contacting the Game Developer, since DirectX12 is a BETA feature of the game.
Let me know if you have further questions.
Andres P.
Andres_Intel
員工
3,325 檢視
Hello LUIS11,
I just want to remind you to contact the Game Developer, since DirectX12 is a BETA feature of the game.
Andres P.
Andres_Intel
員工
3,205 檢視
Hello LUIS11,
Andres P.
回覆
