Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1402 Discussions
intel IPMI fails. Is there any workaround for this problem?
Danila_K_
IPMI
Please review our problem described below. We’re trying to use IPMI for computers that have this capability. We have a machine with Intel Server Board S1200BTL with a possibility to connect via RMM4. We’re trying to work with its motherboard remotely. We access the web interface via http://ipaddress/ and an Integrated BMC Web Console is opened. The following information’s present:
System Information:
Host Power Status :
Host is currently ON
RMM Status :
Intel(R) RMM installed
Device (BMC) Available :
Yes
BMC FW Build Time :
May 25 2012 10:20:47
BMC FW Rev :
01.14
Boot FW Rev :
00.03
SDR Package Version :
SDR Package 1.14
Mgmt Engine (ME) FW Rev :
02.02.00.049
FRU Information
Chassis Information
Type:
Main Server Chassis
Part/Model Number:
Serial Number:
Board Information
Manufacturing Date :
2012-05-05   07:30
Manufacturer :
Intel Corporation
Product Name :
S1200BTL
Serial Number :
QSBT21809255
Part/Model Number :
E98681-352
FRU File ID :
FRU Ver 0.03
Product Information
Manufacturer :
ICL-KME CS
Name :
teamRAY
Part/Model Number :
Version :
Serial Number :
1209TR315
Asset Tag :
39891170100
FRU File ID :
We need to remotely handle the power of the computer, examine SEL (System event log)and receive information about critical events. Studying the docs we realized that the best way to talk to the machine by IPMI is WS-MAN protocol accompanied by Windows Remote Management (WinRM) utility. We realized also that WS-MAN is understood if the motherboard has a Remote Management module. A few problems followed.
Our motherboard supports RMM4 (as displayed both in BIOS and the web interface). We assumed that RMM4 uses the same IP as BMC. Is that correct?
Here’s our piece of code using WinRM:
public static void Get()
            var wsman = new WSManClass();
            var options = (IWSManConnectionOptions) wsman.CreateConnectionOptions();
            if (options != null)
                try
                    options.UserName = "root";
                    options.Password = "root";
                    int iFlags = wsman.SessionFlagCredUsernamePassword();
                    var session =
                        (IWSManSession) wsman.CreateSession("http://10.182.171.195:8889/wsman", iFlags, options);
                    if (session != null)
                        try
                            var identity = session.Identify();
                            var s = "http://schemas.dmtf.org/wbem/wscim/1/cim-schema/2/ComputerSystem";
                            var reply = session.Get(s);
                            var doc = new XmlDocument();
                            doc.LoadXml(reply);
                            foreach (var elementName in new string[] {"p:Caption", "p:Description"})
                                var node = doc.GetElementsByTagName(elementName)[0];
                                if (node != null) Console.WriteLine(node.InnerText);
                        finally
                            Marshal.ReleaseComObject(session);
                catch (Exception ex)
                    Console.WriteLine(ex);
                finally
                    Marshal.ReleaseComObject(options);
At the line session.Identify() we’re getting ComException:
The WinRM client cannot process the request. Default authentication may be used with an IP address under the following conditions: the transport is HTTPS or the destination is in the TrustedHosts list, and explicit credentials are provided. Use winrm.cmd to configure TrustedHosts. Note that computers in the TrustedHosts list might not be authenticated. For more information on how to set TrustedHosts run the following command: winrm help config.
How should we set up network configurations in order to work with RMM4?
Is WS-MAN protocol supported for the above BMC?
Gael_H_Intel
Your board board: http://ark.intel.com/products/53557/Intel-Server-Board-S1200BTL?ui=BIG&wapkw=intel+server+board+s1200btl
Here is the link to the user guide for BMC/RMM4: http://www.intel.com/support/motherboards/server/sb/CS-032371.htm See section 4 on how to configure your network.
Here is a blog that discusses correct configuration of winrm: http://software.intel.com/en-us/blogs/2008/03/24/getting-to-know-ws-man-a-little-better
>winrm quickconfig  -- creates an HTTP listener by default. You may need to create and HTTPS listener:
  • Type the following command: winrm quickconfig -transport:https. You must open port 443 for HTTPS transport to work.
  • Type:  winrm enumerate winrm/config/listener to get a list of all listeners that have been configured.
This forum is not really for Server related issues but I hope the above information helps you.
