您好,请问有实现P2P远程视频播放的样例吗?
Signaling server采用了PeerServer-Release-4.2.1,通过node peerserver.js命令已经运行起来。
但有在Peer A和Peer B上运行的样例代码吗? 谢谢!
- Tags:
- HTML5
- JavaScript*
i do it ok and run success ,please add me email :1213126651@qq.com
Please look at the source code from CS_WebRTC_Client_SDK_JavaScript.v4.3\samples\p2p.
Chunbo H. (Intel) wrote:Please look at the source code from CS_WebRTC_Client_SDK_JavaScript.v4.3\samples\p2p.
The source code in the p2p example can capture stream from webcam in the local machine.
It uses MediaStreamFactory.createMediaStream() to create a video stream( call getDisplayMedia() for srceen and getUserMedia() for webcam).
I want to capture stream from a IPcamera which provides RTSP or RTMP stream, not webcam or screen。
How can I capture the stream from a RTMP url? For example : rtmp://127.0.0.1/live/ (It can played in VLC player)
Below is my code:
<video width="640px" height="480px" id="localVideo" controls playsinline muted>
<source src="rtmp://127.0.0.1/live/" type="rtmp/flv">
<!-- source src="rtmp://media3.sinovision.net:1935/live/livestream" type="rtmp/flv" -->
</video>
var video_element = document.getElementById("localVideo");
mediaStream = video_element.captureStream();
video_element.play();
When I run the code, an error prompted : "Error: All tracks are ended."
Can you tell me what is wrong with the code above? Thanks.
When the <video> source is a mp4 file, such as :<source src="js/array.mp4" type="video/mp4">, the video_element.captureStream() works OK. Mp4 stream can be transported to the remote peer and played OK.
The source code I used has change from v4.2.1 to v4.3
Did this local video element with RTMP play as expected?
Yes, it can be played with VLC player, or played with video.js inside the webpage:
var vsplayer = videojs("localVideo");
vsplayer.play();
I want :
Peer B capture RTMP stream and publish to Peer A.
Peer B can play the locally with videojs, but can not publish to Peer A. It prompted : "Error: All tracks are ended."
Chunbo H. (Intel) wrote:Did this local video element with RTMP play as expected?
Can you tell me your email? I can send the complete code to you.
According to the feedback from our feature owner, we don’t support RTSP/RTMP at client side currently.
![](/skins/images/BC9A7A3465121B56B278007F4EE8899F/responsive_peak/images/icon_anonymous_message.png)
