Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
issue in Android SDK while do unpublish
Gopi_Krishna_P
Hi Team,
When i am doing unpublishing or disconnecting the session  i am getting below exception repeatedly
on unpublishing
publication.stop();
localStream.detach(localRenderer);
capturer.stopCapture();
capturer.dispose();
capturer = null;
localStream.dispose();
localStream = null;
on disconnecting
conferenceClient.leave()
public void onServerDisconnected() {
 if (capturer != null)
capturer.dispose();
capturer = null;
if (localStream != null)
localStream = null;
publication = null;
subscription = null;
stream2Sub = null;
rootEglBase.release();
 then it gives below exception
FATAL EXCEPTION: pool-8-thread-1 Process: com.mobile.telebu, PID: 19217 java.lang.NullPointerException: Attempt to read from field 'long org.webrtc.MediaStream.nativeStream' on a null object reference
at org.webrtc.PeerConnection.removeStream(PeerConnection.java:782)
at com.intel.webrtc.base.PeerConnectionChannel.lambda$removeStream$6$PeerConnectionChannel(PeerConnectionChannel.java:216)
at com.intel.webrtc.base.PeerConnectionChannel$$Lambda$6.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1133)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:607)
at java.lang.Thread.run(Thread.java:776)
Thank you.
Gopi Krishna.
He_Z_Intel
This exception is due to the fact that LocalStream has been disposed at the time peerconnection tries to remove it.
Please try avoiding doing these two operations together, and we will fix this issue in the newer version.
and you can also find the fixing in the most recent code on github.
Gopi_Krishna_P
Any help would be appreciated.
Thank you.
Gopi Krishna P
He_Z_Intel
Gopi_Krishna_P
Hello Hank Zhang,
Thanks for your update :)
Can you please share recent code on github link, i am unable to find that code path.
Thank you.
Gopi Krishna P
Gopi_Krishna_P
Hello Hank Zhang,
Good morning and thanks very much for your reply and updated information. What I am wondering is Intel CS for WebRTC client SDK (https://software.intel.com/en-us/webrtc-sdk) and the link that is sent by you (https://github.com/open-media-streamer) both are same? Please clarify. If both are same and if we get the latest updated SDK with bug fixes in GitHub, we will use GitHub version only.
Thanks in advance.
Gopi Krishna P
